Burning oil bad
Burning oil bad
I installed a tsi kit on my car about a month ago and now the thing burns oil and smokes like none other. Anybody have this prob or any ideas on what is wrong? Any help would be great. Thanks
Re: Burning oil bad
Either faulty turbocharger or damaged pistons/rings.
Check compression, it it's ok, then it turbo itself.
Hope it is turbo, becuase you should have one year warranty still.
Re: Burning oil bad
I did not install the oil pressure reducer. Could that be the problem? I read about it in the instuctions after we were pretty much done with the install. The compression is good and the plugs are the brown chocolat color they are suppose to be. I thought that I forgot the reducer maybe it has to high of oil pressure and it blew out the seals in the turbo.
Re: Burning oil bad
Re: Burning oil bad
i did the same thing, i ran my t3 without a restrictor for a year, and when i finally decided to install it, it was too late. i blew the seals on it and smokes a bit but it's not making it into my intake, so i dont really care. it's an older turbo and i was planning on replacing it this year anyways.
Re: Burning oil bad
http://cgi.ebay.com/ebaymotors/Turbo...spagenameZWD1V
thats what i used, im using the golden eagle oil filter sandwich adapter to feed my turbo. i have that in between the sandwich and the 1/8" npt to -3an line adapter. if you dont have any NPT fittings in your line set, you might be able to find something similar in AN threads.
Re: Burning oil bad
Keep in mind this isn't always necessary, it depends on the size of your feed line. I'm running a -3 line and have no restrictor, haven't since I've had the turbo....
RIPSAW
Nov 6, 2015 04:36 AM
zaboomafoozarg
May 30, 2015 09:21 AM
