Radiator Replacement
Old May 9, 2007
Baldie's Avatar
Baldie is an unknown quantity at this point
I have a 98 civic dx coupe and need to replace my stock radiator. Not planning to upgrade or anythign but I wanted to know if this would be a simple DIY job??
Old May 9, 2007
Syke Fu's Avatar
Syke Fu will become famous soon enough
Re: Radiator Replacement
Yeah it should be pretty simple. Basic hand tools should be all you need.
Old May 9, 2007
skipbarber's Avatar
just be sure to bleed the air out of it once you fill it back up...air pockets in the cooling system are a nasty surprise.
Old May 10, 2007
civicexracer's Avatar
civicexracer will become famous soon enough
its easy. drain radiator, clean reservoir, disconnect hoses from radiator, disconnect fan wire(next to reservoir), remove radiator, remove fan from radiator, place fan on new radiator, install new radiator, connect fan wire, connect hoses(make sure all is tight), fill radiator and reservoir, run engine and fill as necessary. run the engine untill fan kicks in and upper hose is hot. check for leaks. check radiator and reservoir levels to be sure all is well.
thana
Jun 15, 2020 07:05 PM
mrohitredd
18
May 14, 2015 07:35 PM
hokiedad4
May 3, 2015 10:06 PM
thesushiboy
Apr 12, 2015 02:54 AM
RallyEX
Jan 24, 2002 11:12 AM
