D17A2 Engine Parts...
Old May 6, 2007
_SKIN_'s Avatar
Member
_SKIN_ is an unknown quantity at this point
The motor blew up in my car. I replaced the motor, and then sold the car. I still have the old motor and all of the parts, sensors, and what not. You tell me what you want and I will get you the part for a resonable price. Just so you know the motor ran fine before it blew up. There is a sensor on the throttle body that was bad on the new motor, so I replaced it with the one from the old motor.
Old May 6, 2007
Buds302's Avatar
Buds302 will become famous soon enough
Re: D17A2 Engine Parts...
ill give 15 for the intake...? let me know stock intake manifold with injector plate. it dont even need a TB or injectors. i would like the rail though
Old May 7, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
is the head salvageable? if so how much and where u located?
Old May 7, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
i might want your crank and crank bearings. i will let you know once i find out the problem w/ my motor.
Old May 7, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
They typically do. It would help your cause if you specify just what exactly when wrong.... so as to inform people what parts might still be useable.
Gotta use new bearings.... they're not reuseable... especially if you're changing the block they're going in. There are 5 sizes.
Old May 7, 2007
_SKIN_'s Avatar
Member
See pics below... Both holes are only in one cylinder. One on one side of the block and another on the other side. The oil rail in the bottom end is all smashed too. The arm that holds that piston just ripped like a piece of paper.
I have the fuel rail, and the intake. I also have the head. It looks fine to me. The pistons did not slap it. I have all of the sensors, the only one that I know is bad is the IAC. All the rest are fine. I have the wiring harness as well.
File Type: jpg
File Type: jpg
Old May 7, 2007
Buds302's Avatar
i just need the bare intake manifold...injector plate to go with it...and the fuel rail. the rest of it you can keep
Old May 7, 2007
_SKIN_'s Avatar
Member
Ok, I can get that to you. What is the injector plate?
Old May 7, 2007
metalviper's Avatar
so how much for the head?
Old May 7, 2007
thank you boiler for the heads up on the bearings.
Old May 7, 2007
Buds302's Avatar
the intake manifold is two pieces. the pplastic part and a thin injector plate..its about 3/4" thick. but these two parts bolt to the motor. they come off together.
Old May 8, 2007
_SKIN_'s Avatar
Member
$90. I am in Flint Michigan.
Old May 8, 2007
_SKIN_'s Avatar
Member
Okay, Yeah I have that. How about $40 for all three pieces.
Old May 8, 2007
Buds302's Avatar
make it 30 and you gotta deal??? shipping zip is 25404
Old May 8, 2007
AThompson18's Avatar
AThompson18 is an unknown quantity at this point
how much for the main cap
Old May 8, 2007
_SKIN_'s Avatar
Member
Sounds good. I will pm you with payment info.
Old May 8, 2007
_SKIN_'s Avatar
Member
What is a main cap? I would gladly sell it to you if I have it.
Old May 8, 2007
Buds302's Avatar
i think he means one of the main bearing caps for the crank...but im not sure
Old May 9, 2007
Em2onCPRs's Avatar
DU MA Con Cac
Em2onCPRs is an unknown quantity at this point
do you have fuel injectors and coil packs?
Old May 9, 2007
_SKIN_'s Avatar
Member
I have everything that was bolted to the engine. Are the injectors on the fuel rail? Because that is being held for another guy. Where are the coil packs?
Old May 10, 2007
Jap-Euro Fusion
Translation : The motor threw a rod, and blew a hole in both sides of the block. The main cap bridge is smashed.
Boiler's translation: The entire bottom end of the motor is a paperweight. While its highly unlikely that "nothing" happened to the head, it is possible that the head is in salvagable condition, but forget about the bottom end.
Also, the caps have to match the block... you gotta buy them together. The caps dont have size stamps on them, only the block does, and they MUST match or you'll have to align hone the crank journals. While doable it creates an unnecessary headache and a major pain in the *** when it comes to sizing the bearings when its done (and the fairly expensive job of doing the machining).
Old May 15, 2007
Buds302's Avatar
sent you teh money last week?? did you send my parts out?
Old Jun 29, 2007
_SKIN_'s Avatar
Member
Yeah, you should have got them. I have no parts left other than that listed in other posts.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
juror
May 26, 2015 06:35 PM
jmdcivic
May 20, 2015 09:52 PM
Myredjonda
Apr 14, 2015 07:00 PM
Spaulding
Dec 28, 2001 02:41 PM
