Some cool tuning and exhaust related results
Old Apr 17, 2007
dezod's Avatar
7thgen Power Maker
Had a local Dezod Turbo tC customer get tuned from 2 different local shops with horrid tunes. The car bogged, had tons of lag and driveability was ok at best. So I zero'd out the entire tune and started from scratch and instantly she started getting in line.....Tuned the car for 8 and 10 PSI with an e-cutout and here are the before and 2 afters.
Previous garbage tune with 10.0:1 AFRs at 10 PSI--280whp, 278wtq
New tune by me on 8 PSI with e-cutout @ 11.6:1---271whp, 247wtq
New tune by me on 10-11 PSI with e-cutout @ 11.2-11.4:1--293whp, 274wtq
The onset of boost is much smoother, and more agressive, lag was cut down by 300-500 RPMS and driveability is not even comparable.
Old Apr 17, 2007
andyman97's Avatar
Turbo Guru
Re: Some cool tuning and exhaust related results
AEM? Good work cleaning it up. Those torque and power curves were really sloppy.
Everybody needs to pay attention to this. It isn't just a matter of taking your car to a "tuner" because as you see, some tuners can screw your car up.
Old Apr 17, 2007
dezod's Avatar
7thgen Power Maker
Tell me bout it. The car was so laggy and had next to no useable power except for the top end, which is not appropriate on a DD turbo car with low boost like this. We where able to bring on power sooner and broaden the power band of this car quite a bit. Believe it or not, this was done on our tC black box (for partial throttle) and an e-manage for WOT. I tuned two seperate piggybacks to mesh them into this car.
Old Apr 17, 2007
trurace's Avatar
trurace is a jewel in the roughtrurace is a jewel in the roughtrurace is a jewel in the roughtrurace is a jewel in the rough
Did you street tune or dyno tune the TC
Old Apr 17, 2007
TRIZ's Avatar
Very nice, but for thoes of us not around to get tuned by you/dezod, how do you know wheres a good place to tune at?
Old Apr 17, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
thats a catch 22^
Old Apr 17, 2007
dezod's Avatar
7thgen Power Maker
This was 100% street
Old Apr 17, 2007
dezod's Avatar
7thgen Power Maker
Just to get a sheer apples to apples comparison. Here is what I did to the car's powerband bringing less lag and more useable power on the set-up for a DD turbo car. Notice the difference in the cars curves and especially above 5K rpms. This is a T3/TB54 with a Stage 3 .63 A/R wheel on a log manifold.
Before:
After
Old Apr 17, 2007
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Nice job with the curves. It's always a pleasure to hear boost coming on sooner. Better power more quickly = tasty!
Old Apr 17, 2007
WilmncChris's Avatar
WilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of light
Some tuners as about as good as smelly trash. You should see some of the **** we get.
Old Apr 18, 2007
dezod's Avatar
7thgen Power Maker
You saw the schtuff I got here. Nothing new man.
Old Apr 18, 2007
andyman97's Avatar
Turbo Guru
Reputation and word of mouth. With Hondata, they will recommend a good tuner. I would just ask around my area and see who knows what they're doing. If you hear alot of horror stories, staying away may not be a bad idea.
Paul, any reason you tuned the afr that lean? As long as the afr's stay around 12.5 or richer, he should be fine but I would personally feel safer somewhere in the mid-high 11's.
Old Apr 18, 2007
dezod's Avatar
7thgen Power Maker
The AFRS on 10 PSI where tuned to 11.2-11.4:1 and on the dyno with the onset of the turbocharger now, it comes in so fast, it was tough to transition from the partial throttle box, which I had programmed for closed loop to 11.4 AFR once in boost, to WOT with the e-manage to 11.4 AFR. It is the onset of boost, that I could have spent more time on, but the customer didn't want to pay for anymore tuning, and it was late. And for the record, 11.4 is FAR from lean.
On the dyno, he also observed that he picked up an extra PSI of boost (from 10 to 10.8) when running an e-cutout, which it did not do on the street when we where tuning. This also caused a short leaner than liked, scenario, but still well within guidlines of safe once he was all set.
Old Apr 18, 2007
Michalo187's Avatar
Abortion Survivor
it sucks how all the money you have invested in a car can go to complete **** because of a bad tuner. This is what i would say to be the most important step and it completely lies on someone else.
Old Apr 18, 2007
dezod's Avatar
7thgen Power Maker
The way the previous tuners set-it up, he was destined to wash some rings for sure. 10:1. WTF is that?!?
On the street though, this cars AFRS where rock solid on the datalogs.
Old Apr 18, 2007
Ye sometimes the AF ratios do not match the driveablity of the car. Esp on daily driven cars
Old Apr 18, 2007
dezod's Avatar
7thgen Power Maker
I have seen AFRs differ from the street to the dyno. This is not the 1st time, hence why I do both and recheck my work in a system of checks and balances. The street matters much more to me because how often are you under dyno conditions vs street conditions.
Old Apr 18, 2007
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
mmm happens alot. Gotta tune both ways IMO to be consistent on the street. A lot of drag teams dont even bother with dynos once they get basemaps just for this reason, even at best, its only a simulation of real world events which are very hard to duplicate. It never hurts to have a wideband in the car, its relatively cheap insurance.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Inkubus
Bolt-on Engine Performance
Jun 26, 2015 11:42 PM
Supramk3
Jun 11, 2015 11:13 AM
Rogelio Rey
May 24, 2015 08:30 PM
CivicVoz
Apr 16, 2015 08:07 PM
