So my turbo just got installed...but how to make car run normal
Old Apr 13, 2007
karizzle's Avatar
Pinkslip Racer
karizzle will become famous soon enoughkarizzle will become famous soon enough
Ok, how do I start.
A buddy of mine just got done installing a turbo kit on my car. Basically, the car starts, but its a very slow sputtery start like it wants to immediately stall out (doesn't though)
When I put it in drive(automatic, obviously) and give it gas, theres a 35% change the car will imediately stall out, it will kind hesitate and stall, or hesitate and jerk forward, then accelerate like normal.
When it wants to shift from 1st to 2nd, sometimes, I'll keep my foot untouched on the gas and its as if I'm not pushing it at all, the revs will drop and the car will slow down, almost to a dead stop, I've noticed tapping the gas helps a bit to get the car moving again
And sometimes I'll be cruising at 50km/h, about 2k rpm and the car will sudenly just drop revs to 1k, then go up to 2k, then drop to 1k.
I'm keeping the wastegate(internal) open, so it doesn't create any boost until I can get it dyno-tuned. But for the moment, I want(and need) and normal running car. Is there anyway I can go about doing this? I'm using Greddy E-Manage blue, and I know the car is running VERY rich, so I was thinking if I screwed around with the fuel, maybe I can get it running a bit normal? Could screwing around with the fuel settings damage my car?
I was considering going off a basemap of someone else, but I'm not too sure how that works. Do I simply upload it to the E-Manage and drive?
I mean, I'll be honest, I know nothing about doing stuff like that, and I would like to learn to do it myself so I don't have to always have to depend on people...
Any help is appreciated, the sooner the better
Thanks
Old Apr 13, 2007
affixrider's Avatar
affixrider will become famous soon enough
Re: So my turbo just got installed...but how to make car run normal
Are You Running Off Another Aux Fuel Pump? I Had The Same Prob;em Until I Got Mine Tuned. Just Becareful Not To Rev It To High Or Your Blow Your Map Sensor. And In Case You Havent Bought One Yet A Missing Link Is A Good Investment.
Old Apr 13, 2007
Havok2k1's Avatar
Wicked Pissah Admin
We need more info on your setup (fuel, etc)
Most likely it is the settings of the e-manage or the map you used.
Old Apr 13, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
any parts used or are they brand new and also dont know if you have one...but i highly recommend getting a tranny cooler
Old Apr 13, 2007
karizzle's Avatar
Pinkslip Racer
i basically have pieces from a sf kit, used, and a brand new intercooler + piping, with used rsx-s injectors and i believe its a used e-manage
and ya, tranny cooler imma get for sure
Old Apr 13, 2007
54321r's Avatar
54321r will become famous soon enough54321r will become famous soon enough
damn good luck im not sure what im doing yet either turbo or swap..(i also drive an auto for now)
my dad wants to just start a build car he knows cars i dont know as much
Old Apr 13, 2007
andyman97's Avatar
Turbo Guru
Here's what you do. Clean your emanage map to all zeros. Basically let the stock ecu control the injectors. Swap the rsx injectors back out for stock ones until you are ready to dyno tune. Not sure how you're running your wastegate open unless you disconnected the gate off of the turbine housing. If you're running an old sf kit, are you running the fmu or is it just injectors and emanage? If there is an fmu, disconnect it and throw it away.
Old Aug 11, 2007
BruisedCivic04's Avatar
BruisedCivic04 is an unknown quantity at this point
no i just bought a used fmu for my stanford kit , now why exactly would i be throwing i away...??
CarStuff
Dec 6, 2020 12:52 PM
mistermenphis22
Apr 3, 2016 08:06 AM
beneditti
Jan 15, 2016 12:31 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
