Which spring/shock setup is the smoothest riding?
Old Mar 24, 2002
ZGstar's Avatar
ZGstar is an unknown quantity at this point
Is there a smooth-riding (as smooth or smoother than stock) aftermarket lowering spring/shock setup out there? I don't want to sacrifice the stock ride. The stock suspension already rides like a typical (under $20K) economy car, so I can't imagine how rough-riding Race or even Prokit springs would feel.
Why lower your car if you can't drive a 600 mile day comfortably?
Why get rims if you can't lower your car? (fender gap sucks)
Thanks in advance.
Old Mar 24, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
the ebach pro-kit with the konis is a good combo
Old Mar 24, 2002
CivicPro01's Avatar
CivicPro01 is an unknown quantity at this point
yeah i agree with 01civicboi
Old Mar 24, 2002
andypanda's Avatar
andypanda is an unknown quantity at this point
get the ground control coilovers and tokico shocks
Old Mar 24, 2002
ZGstar's Avatar
Aren't most coilovers rough riding? I remember a previous post w/replies with a pretty unanimous opinion that all coilover suspensions may lower the car well but ride rough as sh*t...
I have read posts that say that the Eiback Prokit's ride was "too hard" for their daily commute, and numerous "hard ride" comments on the Ground Control coilovers.
Looking for a smooth ride, and 1" lowering. No such thing?
Old Mar 25, 2002
TOOLOWCIVIC's Avatar
I have Konis and ground control. It rides pretty smooth but I heard it will ride a lot smoother with springs and Konis. Just don't slam your car to the ground and it shouldn't ride too rough.
Old Mar 25, 2002
Bartkat's Avatar
Concensus I have read is that Pro Kit with 1" drop and Koni Sport's can put the ride about as good or as stiff as you want.
Besides I am unaware of any Tokico's available yet for our cars.
Old Apr 18, 2002
Treck's Avatar
Treck is an unknown quantity at this point
if your gonna spend the money for the springs and shocks you should just put that shht on bags
Old Apr 18, 2002
Bartkat's Avatar
I now have the ProKit and Konis on for about 3 weeks. I have them on an EX automatic. The ride at the lowest setting on the Konis is better than stock, cause you don't get that extra soft bounce. You can turn the shocks up till it's stiff as a wagon and really go around corners. I don't think you will find a better setup and the loweing is about an inch. Also it did not need shims or anything to line up.
Old Apr 18, 2002
2cute's Avatar
2cute is an unknown quantity at this point
I would go with KYB shocks and H and R springs. That's just my 2 cents.
Old Apr 19, 2002
Bartkat's Avatar
KYB available for 2K1 Civics?
Old Apr 19, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
I'm ordering my Koni adjustables installed for $650. I hope its worth it because it really sucks to sit in my backseat with my stock shocks and 2" drop..
Old Apr 19, 2002
Bartkat's Avatar
I don't think you'll regret going with the Konis. I keep my rears set on the softest and the fronts set on half way. I don't hardly ever have any weight in the back.
Old Sep 27, 2004
armjr2's Avatar
armjr2 is an unknown quantity at this point
I was thinking about going with ebach prokit spring and the toikco or koni shocks, will that be ok riding on 215-45-17's?
Old Sep 27, 2004
INCivic's Avatar
INCivic is an unknown quantity at this point
are you on crack, noob?
Old Sep 27, 2004
Bartkat's Avatar
ProKit and Konis worked great for my 01 coupe. You can adjust all the way from smoooth to stiff as a buckboard.
Old Sep 27, 2004
Ledbelly's Avatar
Im the man in the box
im riding on tokicos and neuspeed sports and lovin it
Old Sep 28, 2004
FALKEN's Avatar
Civicforums Junkie
moved to the Suspension Performance forum
Old Sep 28, 2004
varmin's Avatar
just a troll who likes to laugh at YOU.
varmin will become famous soon enough
/2 cents
my '01 coupe has sportlines and koni's, and 215/45/17 does NOT work. Of course the sportlines have a slightly lower drop, but I was rubbing the body tooooo much. I couldn't drive at all with heavy people or more than one passenger without grinding it.
i'm happy with 205/40/17's now, but it's more maintenance.
Old Sep 28, 2004
Bartkat's Avatar
About time. The thread's only been here for about 2 years.
Old Sep 28, 2004
nikoscivicex's Avatar
www.8thgencivics.com
nikoscivicex is an unknown quantity at this point
wow, old thread revived.
Old Sep 29, 2004
SHiRO's Avatar
SHiRO is an unknown quantity at this point
which is great for newbies like me
hi everyone
Old Sep 29, 2004
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
to answer the origional question, to get a soft ride that youre looking for and no wheel gap, youre pretty much lookin at gettin bags man. it wont be cheap, but it should ride like a caddy. as far as springs go, no matter what spring you get, it will be atleast a few lb/inch stiffer than stock to compensate for the reduced suspension travel. there is NO way to get around that, unless you cut your springs(not recommended), and even then you have the ride that you already seem to hate. all i can do is recommend the Tanabe DressUp Form springs. they lower it but provide a spring rate that is only slightly increased over stock. but get a good set of shocks and struts, or youll be bottoming out man. likei said, the only thing i see that may meet your expectations is bags....open the wallet.....
Old Sep 29, 2004
TSSCivic's Avatar
TSSCivic is an unknown quantity at this point
Koni adjustable shocks with either Neuspeed sports springs, Tein S-Tech springs, or Eibach Pro-Kit springs. Those will lower your car, not slammed, just enough to lower the fender gap & still pretty close to your factory ride right now. It won't be the same though, just slightly firmer. You probably won't really notice much.
Tyler93
Mar 20, 2016 09:03 PM
skeener51
Oct 1, 2015 05:56 PM
BBrosario
Sep 17, 2015 07:51 PM
