2ndary O2 sensor help!!
Old Apr 12, 2007
Shifty's Avatar
Hey all, I was wondering if anybody knows where the 2ndary 02 sensor going into the Catalytic converter plugs in. The engine is the d17a2 5speed (EX). Does it connect to the main engine harness or is somewhere else?
pleaseeee helllppp
Old Apr 12, 2007
Da1lyDr1ver's Avatar
Re: 2ndary O2 sensor help!!
you should see a plug comming from above the catalitic converter. just look up and it should be dangeling there unless someone ripped it off.
Old Apr 12, 2007
drunkenmagnum's Avatar
what happend that got u into this situation?
Old Apr 12, 2007
andyman97's Avatar
Turbo Guru
No, the secondary o2 does not plug into the main harness. There's only one clip that will fit that sensor though. Did you do a headswap or a motor swap from an a1 to an a2?
Old Apr 12, 2007
Shifty's Avatar
^^^Hey Andyman, thats exactly what i did, i swapped in a d17a2 engine. Thats the only missing part and the car would be running perfect.
So if it doesnt plug into the wiring harness....where does it go?
To clarify, I have both o2 sensors...but i dont have a clue where the o2 sensor that goes into the catalytic converter....Hellpppppp
Old Apr 12, 2007
civic_04's Avatar
civic_04 is an unknown quantity at this point
the two o2 sensors both go in the catalytic converter pipe, one is close to the top of the pipe(below the header) and the other is closer to the bottom, somewhere in the heat shield
Old Apr 12, 2007
andyman97's Avatar
Turbo Guru
Not what he's asking.
Ok, here's a quick what's up....
d17a1 engine=both o2 sensors have wiring clips on the main harness
d17a2 engine=only primary o2 sensor has wiring clip on the main harness
So, did you swap in the a2 harness or keep the a1 harness?
Either way, you will need to relocate the wires for the secondary sensor if you are using an a2 ecu.
Check the link in my sig. They give you the pinouts except for connector A. I just tore my a1 harness apart and ran the four wires separately for the sensor.
Old Apr 12, 2007
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
You just wanna make sure to put the wires in the right spot if you re-pin any part of that harness. It gets expensive if you put things in the wrong spot, hehe. Its easier to screw up than most think. Theres a lot of wires in one tight *** spot.
Old Apr 12, 2007
Shifty's Avatar
Hey Andyman, thank you soo much for the info. Ill give'r a go on the weekend. Hopefully nothing blows up. Repp'd!!!
Old Apr 12, 2007
andyman97's Avatar
Turbo Guru
Shouldn't blow up, just like Gery said, don't get the wires crossed or reversed.
Project2k2
Feb 8, 2004 09:04 PM
