B&M oil cooler **CHEAP** New in Box
I just opened the box to take pics to post here. All materials are new and hardware is in unopened bags. Im looking for 50 shipped to anywhere in USA
SuperCooler rated at 14,400 BTU 11"x6"x1-1/2"
Stacked Plate design
‘Low Pressure Drop’ feature
All aluminum construction
Oven brazed construction
Small & efficient design
Includes installation kit
3/4” thinline coolers are ideal for tight fit locations
3/8” extended nipple fittings providing improved hose & clamp contact
description
B&M SuperCoolers are 100% aluminum construction and use stamped plates sandwiched together to create one of the most efficient oil cooling devices available. Not only does this unique design provide for maximized cooling through more efficient heat dissipation but it also provides a much sturdier cooler which is practically impervious to flying rocks or other debris
description
Re: B&M oil cooler **CHEAP** New in Box
^^^^A tranny cooler and a oil cooler are the same thing.... Even though it says auto tranny oil cooler it can be used to cool engine oil. The reason why is says auto is because it doesnt come with a sandwich plate. If it did they would sell it as oil cooler. The actual unit, line and most of the other fittings have the same part numbers as in the oil cooler box with the exception on a oil sandwich plate. Call or email summit racing and check for yourself...
RIPSAW
Nov 6, 2015 04:36 AM
SoNiCcIvIc
Mar 11, 2002 03:37 PM
