Where did you mount your indiglo switch?
I was wondering for all those people who have APC Speed-Glo gauges installed, where did you put your indiglo switch box?
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
I put mine in the change tray. When they blew on me I took them out and put the digital switch of my new gauges in there too. I never use it so I just figured I'd load it up with switches and stuff.
Guest
Posts: n/a
ok i searched and read all the posts about installing the gauges myself. what i want to know is what all comes with the gauges? i read that double sided tape comes with it...is that on the back of the gauges themselves, or separate? i know nothing about this stuff...so don't be mean with the comments please...[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
thanks
thanks
<< ok i searched and read all the posts about installing the gauges myself. what i want to know is what all comes with the gauges? i read that double sided tape comes with it...is that on the back of the gauges themselves, or separate? i know nothing about this stuff...so don't be mean with the comments please...[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
thanks >>
depends on the gauges, the first set I had didn't come with any tape. All it had was the gauges, transformer, and switch. The last set I got had double sided 3M tape. If you are going to do it yourself, put them out without tape. If your needles stick then go get some double sided 3M tape (if the set didn't come with any) and secure the gauges.
<< was it pretty easy to put it in the change tray? did you have to do any drilling? >>
It was real easy, I just pulled out the dremel and made a hole at the top of the tray big enough to fit the wire in. Getting it in through the front was a bitch but is possible. Then I just used some glue to hold it in place. On mine the wires to the switch had a connector so you could seperate it. If yours doesn't then I suppose you could just cut the wires, run them through the hole, and then crimp them with some spade connectors.
mistermenphis22
Jul 13, 2015 04:43 PM
