Oil Temp Weld In Fitting
Old Feb 28, 2007
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
ok, so I got my morosso aluminium 1/8 NPT weld in bung. Well the threads start high & the back leaves no room for the probe part of the oil temp sender to actually submerse itself in the oil. The very end of it will be touch, the rest surrounded by the bung. What do you think my chances are of the temp readings being accurate, or do you think I need a new bung?
here's pics...
Old Feb 28, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Did you use a wrench and turn it tight? NPT threads are conical, if thats tight, get a tap and run it deeper.
Old Feb 28, 2007
skipbarber's Avatar
where do you plan to have it welded?
Old Feb 28, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
why dont you use one of those shammy things that you screw between your oil filter and the block. the shammy allows you to screw in the sensors into it and it reads the readings from there. it looks pretty neat, dont know if they work well though. once i get my oil temp and oil pressure gauge i think i will get the shammy and save me the hassle. any opinions on these? il get an ebay link.
http://cgi.ebay.com/ebaymotors/OIL-F...QQcmdZViewItem
looks legit to me.
Old Mar 1, 2007
FoSho's Avatar
Above the oil pan but still under the baffle, I ran outta threads
Old Mar 4, 2007
FoSho's Avatar
So any body got any ideas on the readings? You think they will be acturate?
Xuhme
21
Aug 7, 2023 03:40 PM
RIPSAW
Nov 6, 2015 04:36 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
Blazz
Jun 4, 2015 01:04 AM
zaboomafoozarg
May 30, 2015 09:21 AM
