1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
11:5 LS/VTEC issues
Old Feb 28, 2007
1quickhatch's Avatar
1quickhatch is an unknown quantity at this point
11:5 LS/VTEC issues
i have a ls/vtec with ls block,crank,rods with B16(pr3) piston heads and a B17 gsr head. has 1300 miles and when u get on it, it has great pick up and toque, but when it hits 5800 rpms, it loses power and kinda struggles,smokes and spark knocks. i timed it like any other ls (top dead center) my last ls/vtec with ls(pr4) pistons was timed the same and ran great with no problems all the to 9500
it has 11:5:1 comp. ratio and running 55 lbs. of fuel
what could the problem be?
it seems to smoke all the time like it has a broke ring or bad valve seals, but when you retard the intake 1 degree, it doesnt smoke,but then has absolutely no power
Old Mar 2, 2007
PowerWheels86's Avatar
PowerWheels86 is an unknown quantity at this point
it loses power at 5800? it might be the timing... but check to make sure the vacuum hoses and all that stuff is connected... check the tubes make sure there are no cracks etc.. you might be losing pressure when you reach higher revolutions... as for the smoke i have no idea... what colour is the smoke?
Old Apr 30, 2007
elusive_da's Avatar
elusive_da is an unknown quantity at this point
Re: 11:5 LS/VTEC issues
or vtec silinoid????
PiCASSO
Apr 23, 2002 12:38 AM
CIVICTypeRookie
Apr 12, 2002 09:09 PM
bboytius
Mar 29, 2002 09:23 AM
PiCASSO
Mar 10, 2002 01:34 PM
RiCeGrL
Feb 21, 2002 09:07 PM
