Question about turbo PSI
First ill start by saying I have an SF turbo (t3 super60)
Dezod's t3/t4 turbo put out 164whp @ 5psi(which I assume is what it can run safely on stock internals)
I was reading the forums and someone with the exact same turbo I have only put out 160whp@8psi
What I want to know is, is it a possible that dezods t3/t4 @5psi = SF's t3 super60 @ 8psi?
In other words, is 8psi safe on stock interals with the SF turbo
If not, what are the minimum things I need to change to be able to run 8psi safely?
And how do you know how much you can run safely after upgrading some things?
You can run up to 10 psi on stock internals but YOU MUST HAVE the proper fuel management to accomadate for that boost level. The turbo and manifold design of dezod's kit allows more hp to be put down on lower boost. Remember dezod's old kit put out only 150hp on an auto on 8psi but thats going back to his stage 1 kit. I've been told that 10-12psi is the max boost level on a stock headgasket and rsx injectors max out around 200whp which is close to about 10psi.
With an e-shitbox I wouldnt chance more than 8
Bare minimum upgrades are ARP headstuds and a new HG. ARP Rodbolts arent a bad investment either.
Any T3/T4 and a matching T3 footed manifold will work. Put a big turbo on it, you blow lots of air without a lot of pressure.
And you think I'd be able to run 8psi on stock internals with stock fuel management? How much you think the auto tranny can take?
another thing, just asked somenone else and heres what he told me. someone confirm what he is telling me plz
"the whp u get doesnt jsut depend on the psi, it depends on many factors, cfm is a big one
smack a 14b at 8psi on ur engine and lets say u make 180whp
smack a gt35 at 8psi and ull be making somewhere around 300whp..
bigger the turbo more cfm it pushes but then u get more turbo lag etc etc
dont guage urself on howmuch psi can u safely run it at, the question is more howmuch hp can u run it safely at, if u need 600psi to get 200hp or 8psi to get 200 its the same thing...
another thing that desides if its goign to blow or not is what ur tuning it with and whos tuning it, ive seen some stock d16's putting out 300hp.. and ive seen some pop at 150hp..., please do u and ur engine a faver and dont use a fmu... get real managment like crome or uberdata. and 160whp is almsot 180hp + all the extra torque ull have compared to a torqueless honda engine ull feel it Alot!, anyways i have never tooken apart a d17 i dont know how thin its rods are etc, look on the internet for its max safe daily driven hp, i would say around 180-190whp and u should be good."
YOu evidently asked someone with an older model. You cant use crome or uberdata, nor am I aware than an FMU would work without a return line. and the rods in this POS are something on the order of .15" thinner than D16 rods.
What do I look for when looking to buy "proper fuel management" (yes im new to this stuff, but we havent learnt about fuel injection in school yet...ill get there one day...)
By proper fuel management I'm talking about AEM EMS, PCS-XFC, or emanage, with RSX type S injectors. Some ppl have gotten away with an FMU but it's not safe after 5psi on our d17's. In my opinion you will need at least emanage and rsx s injectors if you plan to boost 8psi. Look into PCS-XFC, its a good piggyback that allows our civics to drive better during partial throttle as opposed to emanage. Wilmnchris is using the PCS-XFC with rsx s injectors with the dezod turbo kit making 160+ hp on 5psi with an auto tranny. That's a pretty good as tune I must say...but just keep doing your homework. Try to talk to boosted 7thgens more than previous year boosted guys bc our civics are nothing like there's. The d17 is a funny little motor but with the right setup can make decent power.
alright, well I have emanage and rsx injectors and it will be profesionally tuned. my turbo is the t3 super60, and that at 8psi should make 160whp. i guess there is no problems....
you will prob make more than 160whp with that set-up. i am guessing withing the 175whp range. and yes we can run FMU i have an fmu hooked up on my car right now. safely running at 6psi.
well the dude that owned this kit before me was making 160whp @ 8psi. the only diff between what he had and me is a diff intercooler. unless his tune was ****, im expecting to make the same amount of power
perhaps, i am guessing that the weather conditions were not the greatest where the previous owner was boosted and his tune was a less than decent tune. a buddy of mine is turbo'd d17 with the same fmu as me running 6psi and he hit 161.3 whp on the dyno. that is untuned with an FMU.
mjdiaz89
Jun 21, 2016 09:26 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
cukaracha
Jul 23, 2015 08:50 AM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
