k20 power steering
Old Jan 9, 2007
edrulz2003's Avatar
edrulz2003 will become famous soon enough
k20 power steering
the list that tells me everything i need to put my k20 in my civic says i need a high pressure power steering hose, well i went to Acura and they have like 3 or 4 hoses for the power steering, so my question is what hose is it any body have a picture of the one i need. plz help need for more parts and my k20 will be done on the 25th
Old Jan 9, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
You need the rsx high pressure powersteering hose and the return hose.
Old Jan 9, 2007
kornsined's Avatar
I'm selling one if you need it.
Old Jan 9, 2007
edrulz2003's Avatar
yes i know i need the p/s hose but i dont know what exact one it is and neither does acura i went there today to get it and they said u gotta be more precise cause theres like 3 or 4 hoses to deal with the p/s
Old Jan 9, 2007
kornsined's Avatar
The hose with parts 24, 25, 30 around it is the one I'm selling and is the only one I used in my kswap.
Old Jan 9, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
dont mean to be rude but those guys at acura are a bunch of dumbasses.. haha..
anyways with that said if they knew there thing there are only 2.. i repeat 2 hoses that come off the powersteering pump... there is only 1.. i repeat one (1) high pressure powersteering hose that comes off the powersteering pump and one that is the return... there are only 2 holes on the powersteering pump.. dont know how they are getting 3 or 4 unless you told them in general POWER STEERING... mkae sure you tell them HIGH PRESSURE HOSE coming off the PUMP.. hope that helps
Old Jan 9, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
I managed to keep my Stock Civic line when i ran my hydrolic PS. But now im moving to an EPS anyways lol.
Old Jan 10, 2007
Nameless's Avatar
TURTLEonK
^ Really? the stock one can fit eh... hmmm I'll soon find out!
Old Jan 10, 2007
D5cIvIc's Avatar
Go EPS if you can.
Old Jan 10, 2007
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
So if you go with the EPS off the Si do you also have to use the Si ECU? Does the ECU have anything to do with the power steering? I would figure it would since u are no longer using a belt to control the steering.
Old Jan 10, 2007
kornsined's Avatar
Yes, I'm pretty sure you need the ECU. I'm not a 100% though.
Old Jan 10, 2007
djmota's Avatar
nope the ecu does not control the eps.
Old Jan 10, 2007
D5cIvIc's Avatar
You DO NOT need an SI ecu. It does not have anything to do with the power steering. The EPS system should come with a harnass and control box that will make it work. The power steering pump and pulley on the K20a or k20a2 motor will need to be replaced with an SI Idler pulley set up. Shown below. Brand new, the idler pulley should cost around 80-100 bucks. roughly. I got my eps system for 400.
Old Jan 10, 2007
D5cIvIc's Avatar
i have a custom high pressure power steering line that i got off my friend. He says the way it is routed SOMEHOW allows you to run the hydrolic power steering without cutting into the hood skeleton.
I still do not understand how that would even work since its the actual pulley that hits the hood and there is no way you can angle that. So this information is according to him.
He has an 03 civic with a k20a that he parted out already.
I have the custom high pressure power steering line for the 01-05 civic for anyone of you that wants to get it off of me.
Old Jan 10, 2007
kornsined's Avatar
ah...I figured you needed the ecu because I seen someone selling and ecu together with the EPS system. Check ephatch.com they usually have some floating around.
Old Jan 10, 2007
D5cIvIc's Avatar
I didn't want to jack this thread, so i made my own. All k-swappers go here:
https://www.civicforums.com/forums/7...ml#post4127027
RIPSAW
Nov 6, 2015 04:36 AM
hans.pcguy
Jul 12, 2015 12:19 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
hayden55
Jul 8, 2015 11:38 PM
cgavin1
Jul 7, 2015 07:10 AM
