Vehicle Speed Signal Circuit (VSS) question
Old Jan 2, 2007
Storm897's Avatar
Storm897 is an unknown quantity at this point
I searched previous threads and found that the Vehicle Speed Signal (VSS) wires were found in 2 places:
1.) Behind the glove box next to the ECU/PCM.
2.) Its also on the left of the steering column in the cruise control module.
I am looking for the 3 pin connector to the vehicle speed signal circuit. I am trying to test my VSS to diagnose a problem but cant find it on my 2001 EX 5spd.
A picture of the connector can be found here.
I searched behind the steering column, glove box, and beneath the car around the manual transmission case but couldn't find it.
Thanks in advance,
Oren
Old Jan 2, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Looks like it's under the hood beneath the intake resonator.
File Type: pdf
Old Jan 4, 2007
Storm897's Avatar
Awesome. Thanks.
Its actually near the Manual Transmission Case above the front sway bar. It was a pain to get to.
Old Jan 4, 2007
bobsagator's Avatar
Manual says for replacement to remove intake resonator then unplug sensor, apparently not as easy as it sounded.
If I may ask, what does the VSS do?
Old Jan 8, 2007
Storm897's Avatar
Its used to tell the car how fast your traveling. I had to run checks on mine to see if it went bad. Trying to diagnose why my damn battery light is on.
edspyhill09
Jun 12, 2016 02:45 PM
juror
May 26, 2015 06:35 PM
Fastfebur
Apr 22, 2015 01:37 PM
supercivic01
South
Nov 30, 2001 11:27 AM
