Neuspeed Strut bar install help!
Old Mar 20, 2002
BLiTz's Avatar
BLiTz is an unknown quantity at this point
If anyone has detailed instructions on how to install this strut bar please advise.. Also if someone could explain what the nut that they supplied is for. Thanks!!!
Old Mar 20, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
Mine came with instructions, anyways the nut is for moving one of the fluid reservoirs, just fit the bar over your shock towers to see where it goes, then loosen the appropriate nuts, put the bar on , then torgque the nuts to the speicfied setting (33 ft*lbs), its a pretty easy mod, just search and you should find more than enough info.....
Rogelio Rey
May 24, 2015 08:30 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
CapYoda
Nov 20, 2001 10:36 PM
andylao
Nov 4, 2001 01:19 PM
3rdcivic
Oct 24, 2001 12:19 PM
