Neuspeed Strut bar install help!
If anyone has detailed instructions on how to install this strut bar please advise.. Also if someone could explain what the nut that they supplied is for. Thanks!!!
Mine came with instructions, anyways the nut is for moving one of the fluid reservoirs, just fit the bar over your shock towers to see where it goes, then loosen the appropriate nuts, put the bar on , then torgque the nuts to the speicfied setting (33 ft*lbs), its a pretty easy mod, just search and you should find more than enough info.....
Rogelio Rey
May 24, 2015 08:30 PM
