Greg & sugaray !!need help for progress sports springs
Old Mar 20, 2002
HeartbreakkiD's Avatar
HeartbreakkiD is an unknown quantity at this point
hey guys~~ i got the springs 2 inches lower my car 2 days ago..
i feel bad when i have a turn, a strange sound....like scratching my fender at the back wheel......is that normal?? the springs at the back wheel like squezing ..kind like that.......
Greg and sugarray!! u two have same spring as mine, would u guys tell me that is that normal?? i have only stock structs on it....
wat can i do now?????
Old Mar 20, 2002
Irishman's Avatar
Irishman is an unknown quantity at this point
I had a problem with my coil overs making a cracking noice. thought it was an axle problem but it was the metal plate on top of my coil overs grinding on the plate from my struts
Old Mar 23, 2002
inca's Avatar
inca is an unknown quantity at this point
I just got my Progress springs about a week ago..dropped 2". Every once in a while if im going fast and turn I'll hear that noise you are talking about. I don't think theres much you can do about it, i think it's "somewhat" normal.
Old Mar 23, 2002
SugarRay's Avatar
SugarRay is an unknown quantity at this point
Hey,
When I first had the springs and was testing the drive, I would hear something to that effect you are decribing.
When I would turn hard ( everything stock except springs, no struts and the like), I would hear a "thump" noise which can be described also as "cracking" from the rear of the car. I also noticed it from the upper right portion of the car when making those hard turns.
So I went back to the shop who installed the springs, they looked at it and said everything was perfectly fine. I then went to get a 2nd opinion at a tire shop, and they said it was ok as well. But the recommended that I get a realignment and such. I declined.
After 2 weeks of the sound, I haven't heard it since. I'm still stock in the suspenision department, and have had no problems whatsoever.
Althouh, after 2 months the rear did "settle in" and matched perfectly with the front, so I'm happy about that.
Ray
Old Mar 23, 2002
inca's Avatar
SugarRay: good to know man, thanks
nirvanaguy
25
Oct 26, 2017 07:26 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
