8th Gen 2006 - 2011.
Front upper strut bar
Old Nov 1, 2006
don007's Avatar
don007 is an unknown quantity at this point
Question Front upper strut bar
I have a 03 Civic and I am trying to install the strut bar and I found the break/cluch reservoir is in the way, does this have to be moved or am I doing somthing wrong?
Old Nov 1, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
it can be easily relocated if you make sure that you use the right hose so it doesn't crimp.. 'cause that would be bad.. does it seem like it'd fit otherwise? that mostly means you bougth a cheap one.. i had to relocate m y horn when i got mine for the subaru
Old Nov 2, 2006
Wadely's Avatar
Wadely is an unknown quantity at this point
My Buddies Ep We Had To Move The Fuse Box For The Injen Cai
Old Nov 2, 2006
don007's Avatar
Thanks to all, I unbolted it and was able to rebolt the unit 3 inches lower, all works fine. Thanks again for info.
GH04si
Apr 15, 2015 08:13 PM
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
PlatnumBomb
Nov 9, 2001 01:11 PM
andylao
Nov 4, 2001 01:19 PM
