8th Gen 2006 - 2011.
What type of gas do you use?
Old Sep 23, 2006
thebighappyhouse's Avatar
thebighappyhouse is an unknown quantity at this point
Just curious...
what kind of gas do you use in your new 2006 Civic?
87 or 89 octane?
Chevron..Shell...76...mystery gas....
Old Sep 23, 2006
MordeKyle's Avatar
MordeKyle is an unknown quantity at this point
Originally Posted by thebighappyhouse
Just curious...
87 or 89 octane?
the cheap **** from QT
Old Sep 23, 2006
Ahhhhh...mystery gas. LOL!
Whatcha paying for it?
I live in Sonoma CA and right now reg unleaded is $2.79 a gallon....it was up to $3.67 about 2 months ago.
Old Sep 23, 2006
MutantCheese's Avatar
MutantCheese is an unknown quantity at this point
Cheapest that I can find. I actually got my last tankful at $1.99 per gl. I was passing the station at 6:30 in the morning and the attendant was changing the board, when i saw the "1", I made a u-turn and filled up. I bragged and showed everyone at work my receipt as proof, but by the time we all got off the price was back up to $2.16 gl, which is still pretty good, concidering...
Old Sep 23, 2006
d3crypt's Avatar
d3crypt is an unknown quantity at this point
The manual says 87 or higher... unless you have an Si... says 92 or better for them.
92-93 will not give you more performance unless you are running high compression than what is stock.
Just curious...
87 or 89 octane?
Old Sep 23, 2006
MordeKyle's Avatar
$1.99 a gallon
Old Sep 23, 2006
pico's Avatar
pico is an unknown quantity at this point
87 octane only. With this car you wont get better milage or performance with 93. Only pay @ 20 cents more per gallon.
I usually buy Chevron/Texaco because thats the credit card I have. I always fear off brand station gas quality. Truth is, they say most gas is the same when it gets to the station. Then the name brand stations pour in whatever additive their corporate headquarters use (ie Chevron with Techron).
Old Sep 24, 2006
MordeKyle's Avatar
probably right you are, i use Quick Trip because it is a huge chain, and i wanna stay consitent with the gas i use and QT's are everywhere around here. plus with all of the business they get, if they **** up, CLASS ACTION!!!
Old Sep 24, 2006
SLRMclaren's Avatar
SLRMclaren is an unknown quantity at this point
I use QT also, sometimes chevron, its like 2.19 over here
Old Sep 25, 2006
X026092's Avatar
X026092 is an unknown quantity at this point
Yes, the cheap gas works fine.
Old Sep 25, 2006
DeeAliganga's Avatar
DeeAliganga is an unknown quantity at this point
i use 89 from exxon. and only that, never used anything else
Old Sep 26, 2006
Wadely's Avatar
Wadely is an unknown quantity at this point
They Say To Use Premium In Vehicle With Hi Compression Such As The Si, Usually With Compression Ratios Over 9.5 Or 10 To 1, So Keep In Mind The Base Model Civics Also Have Over A 10.1 To 1 Compression Ratio, Therefore I Use Premium In My 06 Lx
Old Nov 10, 2006
06civicuser's Avatar
06civicuser is an unknown quantity at this point
I use Shell 87 octane in my civic ex coupe auto.Runs good with it.
Old Nov 10, 2006
landonab's Avatar
landonab is an unknown quantity at this point
Blue (89?) from amoco. have bought gas there for 10 years, never had problems with it.
edit: sorry, I forget these forums are not generation specific. I have an 05 and this thread is for 8th gens.
Old Nov 11, 2006
06CivicHybrid's Avatar
06CivicHybrid is an unknown quantity at this point
i don't really it think it matters for gen specific.
i use 93 % on all cars and 87 for the Hybird, well 93 is only type offered here in JP so its all good.
Old Feb 20, 2007
GTOCivic's Avatar
GTOCivic is an unknown quantity at this point
I would advise against using Premium. If the car is designed to run on 87 octane and you put 93 octane in you will have unspent fuel build up in your engine.
You may be able to get away with 89 octane since this is a higher compression motor and with some spirited driving you should be able to, 'blow the carbon out', but I wouldn't go as high as 93.
Old Feb 21, 2007
Stick's Avatar
Stick is an unknown quantity at this point
I filled the tank (11.5 g) with 92 octane by accident, and got 1.5 mpg less than with 87. I'm sticking with 87.
Stick
Old Apr 16, 2007
20strong's Avatar
20strong is an unknown quantity at this point
Re: What type of gas do you use?
I run nothing but Shell 93 octane V-Power in my Si.
shaejb15
Jul 27, 2015 03:48 PM
jody501
Jul 10, 2015 11:01 AM
cgavin1
Jul 7, 2015 07:10 AM
