8th Gen 2006 - 2011.
Maintenance Minder
Old Jul 25, 2006
bigman32hockey's Avatar
bigman32hockey is an unknown quantity at this point
Maintenance Minder
I have about 2,700 miles on my 2006 Civic EX sedan. Currently, my Oil Life indicator reads 70%. I called the dealer today and asked whether I should have an oil change done at 3,000 miles or wait for the Oil Life indicator to read 15% or lower. He said I should wait for the Oil Life indicator because it was much better at showing oil quality in the engine than going strictly by miles. Are others out there following this advice, or are people brining their cars in for oil changes every 3,000 miles, regardless of the Oil Life indicator? Thanks!
Old Jul 25, 2006
DeeAliganga's Avatar
DeeAliganga is an unknown quantity at this point
hmm wow , i'm at 2133 miles with 70 percent ....
Old Jul 25, 2006
The service guy said the oil life depends on many different factors (i.e. driver style, climate, oil used, etc.), so I guess it could make sense that we have different mileage, even though the Oil Life indicator reads the same percentage.
Old Jul 25, 2006
kero's Avatar
kero is an unknown quantity at this point
I just did my first oil change at 2700 miles, changed it with penzoil 5w-20 and normal frame filter.
After this, I use synthetic blend oil with a high quality pure-one filter and change every 5000 miles from there on.
Old Jul 26, 2006
ndoelling's Avatar
ndoelling is an unknown quantity at this point
I am going to have my first oil change this week, ~5K miles on car and oil life is only down to 40%. Even though it is only this low, 5K miles is plenty I think to have broken in. Anyone else smelled the oil in the car when you bought it? Mine smelled like gasoline; dealer said it was a high detergent oil. thoughts? I think it might have been to better carry away particles generated during break-in, thinner oil.
Old Jul 26, 2006
MordeKyle's Avatar
MordeKyle is an unknown quantity at this point
my dealer told me to wait until the indicator came on, i got my oil changed around 6500 miles.
Old Jul 27, 2006
I read somewhere (possibly the manual itself) that the oil they ship the car with is different than regular oil. They said it is supposed to help the engine during the initial break-in period. Not 100% sure that's correct.
Old Jul 27, 2006
Terry Wright's Avatar
Terry Wright is an unknown quantity at this point
mass spec on the cheap
Just to mention, Honda uses a mass spectrometer set of LEDs. It's mass spec on the cheap to read the oil. Follow the minder and set older paradigms aside - this is a a redesigned Civic. Even the technicians are working to adjust their procedures.
from my corner,
Terry
Old Aug 1, 2006
Shishpanik's Avatar
Shishpanik is an unknown quantity at this point
That probably is correct because ive heard that that oil is scheduled to last approx 5k miles while you should change your oil every 3 k miles after that.
Old Aug 5, 2006
koreth's Avatar
koreth is an unknown quantity at this point
I used to always change my oil every 3k miles, no question asked... From what i've read most Honda people are recommending following the minder... Here's my question though... If it detects oil life and how good it is and when you should change it... When you DO change it, WHY doesnt it recognize that its new oil and reset itself? You have to manually reset the minder to 100% correct? I still have a couple thousand miles to decide which advice i want to follow but just thought i would bring that up and see what you all think...
Old Sep 23, 2006
d3crypt's Avatar
d3crypt is an unknown quantity at this point
Apparently none of you guys have read your manual!! The oil life is figured by counting the total revolutions of the motor, temperature, driving conditions, and etc. It doesn't actually TEST the oil itself. I'd think it'd be a good idea to change the oil around 10-25% but thats just me. Oil companies, for years, have told us that we should change our oil every 3000 miles but with new technology in refinment and engines... most new car's owner manuals tell you every 5000-6000 miles now. READ THE FRIGGIN MANUAL. That is all.
Old Jul 9, 2007
plastics's Avatar
plastics is an unknown quantity at this point
Re: Maintenance Minder-how to reset?
Would anyone be able to tell me how to reset the maintanence minder on the dash
Plastics
07 Civic EX Sedan black
Old Jul 10, 2007
BTRobertson's Avatar
BTRobertson is an unknown quantity at this point
I did my first oil change at 500 miles with regular oil (to let the engine properly wear in with normal oil), then I change it every 3,000 with 5w-30 full synthetic Mobile One or Castrol Syntec. With the driving conditions in Pittsburgh (i.e. stop-and-go quite a bit during the summer construction months), it's much better that I change it more frequently with higher quality oil. It also depends on how you drive the car. I've read that the Maintenance Minder will actually adjust its schedule to fit the way you're driving the car. So if you're more aggressive, chances are your maintenance routine will come up quicker than someone who drives more conservative.
I spent the other evening reading the entire manual, which I've never done for any car I've ever owned. It's pretty enlightening and I would recommend everyone read it. For example, in the Si model, they don't recommend putting any oil additives into the oil because it could damage the engine. ??? I've been putting oil additives in every car I've owned and none of them have ever damaged the engine. Can anyone shed some light on that?
Last edited by BTRobertson; Jul 10, 2007 at 07:11 AM. Reason: Needed to add email notification
Old Apr 14, 2008
dcubed121's Avatar
dcubed121 is an unknown quantity at this point
Plastics
Read the manual and if you refuse to read the whole thing then at least read the maintinence portion. it will answer your question.(and a whole lot more interesting stuff.) plus i really just don't want to go get mine out of the car to tell you.
Old Apr 22, 2008
jatniel's Avatar
jatniel is an unknown quantity at this point
Honda Maintenance Manual does not recommend use synthetic oil.
Old Apr 30, 2008
rayzke's Avatar
rayzke is an unknown quantity at this point
I wonder why?
Old May 1, 2008
rocksinger's Avatar
rocksinger is an unknown quantity at this point
RE: Honda manual, there is a PDF version of the manual if you sign up your car at Honda's web sit. I downloaded it and often go to it for 411
I own a 2008 Black 4 door EXL with NAV with almost 10 g's on it and have made friends with the service adviser at my local Honda dealer by giving him gifts from Honda Japan from one of my many visits there and he said to wait 5 g's before changing the oil and NOT to use Synthetic oil.... he was trained by Honda
Old May 3, 2008
vaff's Avatar
vaff is an unknown quantity at this point
I emailed the service guys about this issue, and they said that the Civics are sold with semi-synthetic 5W-20; to NOT use straight synthetic oil, and to follow the maintenance minder.
For me, it's as much a trust issue as anything else; to overcome the habits I've had to change the oil every 5k and rely on a computer rather than an odometer to make that decision.
Old May 12, 2008
07exNavi's Avatar
07exNavi is an unknown quantity at this point
I am going to change my oil around every three thousand miles, regaurdless of how good the oil is it is better to have cleaner oil in the motor.
SammySC
121
Apr 7, 2017 07:43 PM
WWJD
Sep 23, 2015 12:56 PM
SidCivic
17
Aug 23, 2015 03:14 AM
