c/a intake help
Old Mar 20, 2002
inciviccord's Avatar
inciviccord is an unknown quantity at this point
c/a intake help
i installed a c/a intake last night on an lx, i connected the air flow sensor ( or what looks to be that sensor ) into the intake. check engine light on.. any help?
thanks
Old Mar 20, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Make sure you plugged it in as far as it will go. I've heard of many people getting the check engine light...
Old Mar 20, 2002
avenger's Avatar
avenger is an unknown quantity at this point
its a temp. sensor isn't it?
yeah check the cable this happened with me b/c when I put mine on I disconnected it from the harness to work on something underneath, and I didn't re-attach it like a doofus (it was 1 a.m. and I was drinkin that friday night so oops)
Old Mar 20, 2002
robbclark1's Avatar
Retired suspension supermod.
RESET the ECU!!!!! the car doesn't like the increased airflow. U have to reset the computer!!!
Old Mar 20, 2002
jamesbbh's Avatar
jamesbbh is an unknown quantity at this point
no its not the computer b/c mine didnt come on when i put my injen cai on. just go through the whole intake and makesure everything is hooked together good and then makesure the sensor is in the hole tight, your computer will reset itself and adapt to the intake in like 200 or 300 miles
James
Old Mar 20, 2002
avenger's Avatar
<< RESET the ECU!!!!! the car doesn't like the increased airflow. U have to reset the computer!!! >>
nah you don't have to, I never did... our obd-II pos's can learn
Old Mar 20, 2002
the1sthotboy's Avatar
the1sthotboy is an unknown quantity at this point
turn on car...dont accelerate..turn off...turn bak on ..dont accelerate for 5minutes each time.....then turn off again.. and turn on car, then accelerate so the computer can get acustomed to the airflow and CHECK ENGINE SHOULD DISAPPEAR
-hope it helps
UltraHDGames
Jun 8, 2016 05:16 PM
ThatGuy913
Nov 9, 2015 06:31 AM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
thaler4cuse
Sep 7, 2015 08:25 PM
