Car hickup. any ideas whats wrong?
Old Dec 12, 2006
04NiGhTHWK's Avatar
04NiGhTHWK has a little shameless behaviour in the past
Exclamation Car hickup. any ideas whats wrong?
Hey guys. Im new so go a lil easy. Anyways I own a 2004 civic ex. Well since this was my first car its all i know. Anyways when I come down from like 4k rpm to like 2 my car kind of hickups. IS this normal or is it a concern. So basically the car like mildly hkups and jerks foward. plz when you have time help me.
Thanks a bunch!
Old Dec 12, 2006
sl33pyriceboi's Avatar
do u have an auto or manual....and explain it a little better...
/////////edit
and when u feel that hickup, what gear r u on or are u on neutral...etc...
Old Dec 12, 2006
04NiGhTHWK's Avatar
OK its a manuel. Ok so say im in 4th gear and there is a red light ahead. I will shift into 3rd then 2nd. As im approaching the light im in 2nd gear at about 2-3k RPM. as the cars rpms go down it has like a lil tweek and it pushes foward a little bit. Any idea now?
Old Dec 12, 2006
Str8UpCivic's Avatar
Tire Spin
Str8UpCivic will become famous soon enough
are u shifting right? it could b the way u are down shifting
Old Dec 12, 2006
04NiGhTHWK's Avatar
Well I put the clutch in and shift down let the clutch out. What do u mean by shifting right?
Old Dec 12, 2006
04NiGhTHWK's Avatar
MMMm also when my car sometimes reaches like 3-4K when im accelerating it kinda has that hickup. What is wrong IM SO LOST!
Old Dec 12, 2006
04NiGhTHWK's Avatar
PLZ someone diagnos the prob for me. I really need it. IS it cause i didnt break the car in right? i bought it new. Ya i have to admit that within the first 5000 miles i did shift hard a cpl of times/
Old Dec 12, 2006
ian01ex's Avatar
ian01ex is an unknown quantity at this point
Chill out, its the middle of the day. Let people get home from work and respond before you start freaking out.
Old Dec 12, 2006
04NiGhTHWK's Avatar
OK man thanks. I hope someone can help solve the prob. I just want to make sure my honda is running right and doesent have a prob. u know what i mean
Old Dec 12, 2006
CenZ's Avatar
PWIT
what he means by shifting right is rev matching. are you matching up your rps or just going from 4th to 3rd and letting your rpms jump back up to 6k. thats a no no.
Old Dec 12, 2006
04NiGhTHWK's Avatar
Can u please go into a lil more detail on rev matching. Usually when i go from 3-2 my rpm is at like 4 or 5 K
Old Dec 12, 2006
CenZ's Avatar
PWIT
Originally Posted by nasaproracing.com
Upshifting
Upshifting should be done smoothly. Speedshifting will shorten the gearbox life. The only time I force an upshift is in a side by side race to the next corner, for position. I will sometimes “bang a gear” in an effort to take or hold a position. Listen to the in-car shifts of professional racers on TV, and they rarely bang shifts. Upshifts are done quickly and smoothly, but are not forced. If you want your gearbox to have a long, happy life, feel the gears, the changes should fall in, without being forced.
Downshifting
The first thing to understand is the purpose of the downshift. It is not to slow the car, that is the job of the brakes. The purpose of downshifting is to have the car in the correct gear to accelerate through and out of the corner.
Here is the process:
As you enter the braking zone, apply the brakes, but do not immediately downshift. The downshift should be done after the RPM’s have dropped, but must be complete before you begin the turn-in. Downshifting too early can over-rev the motor, waiting too long means you will be rolling the car through the corner entry, giving up the ability to use the throttle to balance the car.
Heel toe Downshifting
Why is “Heel toe” important? Remember, as you approach the traction limit of your tires, anything that takes traction can cause the car to slide. Have you ever downshifted and released the clutch too quickly and felt the car jump as the engine RPM’s were forced up to match the cars speed? Kind of like tapping the brakes. Think of this, if you are driving at 70 mph in 4th gear, at 4000 rpm’s and shift down to 3rd, your engine rpm’s will go up, to say 5200 rpm’s. You can accomplish this by easing out the clutch, until the engine is forced up in rpm’s by the car. This works, but it is slow, hard on the clutch and transmission synchros, and uses up some of your traction to force the RPM’s up. The alternative is to match the engine speed to the transmission speed (in the lower gear). This can be done by pushing in the clutch, blipping the throttle, selecting the lower gear and releasing the clutch. The problem is, downshifting is done at the same time we are braking. Guess what, we have two feet and three pedals to operate simultaneously! The Heel Toe technique solves this problem.
“Heel toe” is a misnomer. It can be done in many ways, depending on the pedals in the car, and the anatomy of the driver. Although it can be, it is not usually done with the heel and toe. The process is commonly done by placing the ball of the foot on the right side of the brake pedal, and while holding consistent brake pressure, the side of the foot rolls onto the throttle, “blipping” the throttle. Depending on your anatomy, and the pedals, it can be done any way that allows the brakes to be used while the throttle is blipped.
Heel Toe cannot be done smoothly unless two things are done:
1) The pedals must be matched. Normally this is done by adjusting until the brake and throttle are even in height, when the brakes are pressed on. The pedals must also be properly spaced. In my car it required adjusting and bending the gas pedal until I got the match I needed. In many cars, the pedals have some range of adjustment, making the process easier. One thing to remember, as you adjust the gas pedal, make sure that there is a mechanical stop for the pedal. If you rely on the stops in the carburetor or injection system to stop the motion, you will probably bend or break something as you try to squeeze a couple more horsepower out of the pedal. Also, make sure the linkage allows the butterflies in the carburetor to be fully open when the pedal hits your mechanical stop.
2) The technique must be practiced. Do not come to the track, with the intention of learning to Heel Toe. Learn the technique on the street, and practice it until it is second nature, before trying it at the track. If your street car is different from your track car, and your street car has a manual transmission, set its pedals for Heel Toe, and learn the technique. Try to get the pedal arrangement similar for both cars. If you must learn the technique in your track car, make it low on your priority list. When driving the line is second nature, you are comfortable in traffic, you’ve got all of the corner stations figured out, start working on it.
Heel Toe is not a required skill at your first event or two, as a matter of fact, you don’t ever have to learn it. It is a tool that will make you a smoother driver (ie. faster!), and you will be easier on your equipment. It’s a tool to add to your arsenal of skills as your high performance driving becomes more polished.
detailed enough?
Old Dec 12, 2006
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Real question...SO I'll answer.
Have you noticed that when you say shift from 2nd to 3rd or 3rd to 4th that your rpms drops? The gearing ratio changes, therefore your rpm drops.
Now when you downshift...remember that drop in rpm? Well if your changing the ratio back from 3rd to 2nd or 4th to 3rd there is going to be a jump in rpm. You need to learn how to tap the gas while you step in the clutch to change gears. This will bring the engine up in rpms that you need to be at for the appropriate gear. This will get rid of the jerking.
It takes a lot of practice to get this done right, because if you over rev. Meaning you rev the engine to high and let the clutch out...your car will jerk forward(speed up) then slow down. If you underrev which is what you are doing, your car will jerk as the rpm suddenly change and slow down.
Do a search on rev matching. This should pull up a lot of threads that you can read through and get a better idea. If you still don't understand the concept or are having a hard time getting it to work then ask a real question.
Old Dec 12, 2006
04NiGhTHWK's Avatar
OMG OMG thanks alot. Ur very kind. Yes that was an excellent read.
Old Dec 12, 2006
04NiGhTHWK's Avatar
Ya thanks for the heads up everyone. This should help. maybe il go for a lil drive!
Old Dec 12, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
yeah you just have to learn to rev match downshift and you will be fine. ... make sure you learn how to do that cuz downshifting with no rev match can damage a lot of stuff in the car. motor mounts, tranny, clutch, etc. just do the same downshifting technique your using but add in a little throttle.
Old Dec 12, 2006
04NiGhTHWK's Avatar
thx for da help man!
mikemc422
Aug 9, 2018 05:41 PM
usajags84
15
Aug 19, 2015 03:12 AM
Braun
Apr 23, 2015 09:03 PM
GH04si
Apr 15, 2015 08:13 PM
dooner24
Apr 14, 2015 07:51 PM
