huge problems with swap and vafc-ii
Old Dec 3, 2006
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
ok, so i got a vtec head a while back for my head swap, but then i bent the rods in my a1 and decided to pull the whole motor. well i found an a2 for $400 so i swapped it in. decided not to swap ecus because the one from the car i got the a2 out of was an auto and i wasnt going to search for one. all connections worked fine except for anything vtec related. installed my vafc-ii and now im having a few problems. i just got the car running at about 10pm and it idles fine, but my redline is at about 3500 and when it hits high cam it sputters like a son of a bitch. i know its probable something out of whack with the vafc-ii but i dont have a user manual or anything for it so im pretty much stuck. ive also got a CEL but i wont know what that is until i go get it checked tomorrow. anyone have any suggestions on what i can do to raise the redline and why it sputters after crossover?
Old Dec 3, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
the redline is a safe mode function. For some reason it doesnt like something. My guess is the LX ecu is looking for one number, and the EX engine has a different parameter, therefore its disagreeing and shutting the motor down. OR, you got a bad sensor in the junk yard motor. Scan the code, start there. Wiring is always an issue. as far as the crossover sputter, you're gonna need to just get the thing tuned so it crosses over smoothly, or find a VTEC ecu.
Old Dec 3, 2006
i got a pdf version of the manual and its a pain in the ***. im thinking i didnt do something right in the learning functions. im going to go screw around with it for a minute. if anyone has a step-by-step setup that has done a a2 head swap with vafc-ii, i would appreciate it.
Old Dec 3, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
i agree with boiler..sounds like the ecu is putting you in limp mode cause something is outta wack. scan the code and let us know what you find.
Old Dec 3, 2006
i looked on the vafc-ii during engine run and there is no change in manifold pressure at any rpm.
Old Dec 3, 2006
Jap-Euro Fusion
but what is the AFC reading it off of? If you have no MAP pressure reading then there's you're limp mode right there. But you need to see what the ECU is reading for MAP pressure. Get a scan tool with realtime streaming and plug it in.
Old Dec 3, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
I think the AFC taps into the MAP sensor wiring, check your map sensor and make sure its plugged in and hooked up correctly.
Old Dec 4, 2006
p0107 is the code. low map sensor input. im going to check the wiring and swap map sensors and see if it clears it. i also went to kinkos and printed an instruction manual so i can have it out there with me.
Old Dec 4, 2006
swapped map sensors and even bypassed it on the vafc. erased the code and it comes right back. going back to check more wiring.
Old Dec 4, 2006
shes alive. all is good but its runnin pig rich. gonna have to get it on the dyno asap.
Old Dec 4, 2006
ok back to the land of problems. idle is surging and ive got 3 codes. the first one it pulled twice. p0507 idle control system rpm high. the other is p2279 intake air system leak. i figure the second one is a vacuum leak somewhere and thats causing an idle surge. gonna swap out all sensors tomorrow. anyone got any input?
Old Dec 4, 2006
kasimmmmm's Avatar
nice.. i'm glad you got it running...
Old Dec 4, 2006
even with the codes i cant help but drive it. i raised vtec engagement to about 6 grand and it hits hard for a d17. shes parked for the night and ill try to solve problems tomorrow. still have to put the hood and bumper back on too.
Old Dec 4, 2006
XSRCivic's Avatar
FYI that "hit" you speak about isnt what you think. what's happening is that your power is flat until the changeover point you feel that boost of power. Its fun to "feel" the VTEC engage but ultimately useless. Get it on a dyno after you get it running right so you can lock in the proper engagement point.
Old Dec 4, 2006
skipbarber's Avatar
the IAC valve could be either unplugged or stuck, check the wiring and tap on it with the car running, if it idles better, replace it.
Old Dec 4, 2006
what about intake air system leak? where would a vacuum leak be on the IM?
Old Dec 4, 2006
Mike04Civic's Avatar
Mike04Civic is an unknown quantity at this point
My moms 04 civic LX (no swap or anything) Is throwing those same codes!!!
only I can hear something hissing from under the dash, until i hit the gas.
I'm taking it to Honda friday since hers isnt modded exstensivly it'll be under warranty....We're hoping.
Old Dec 4, 2006
i dont hear any hissing which indicates a vacuum leak but you cant hear **** over my intake and exhaust.
Old Dec 5, 2006
shes running fine now. cleared the codes and drove it around all day. i do notice when i stop the diel stays about 1500-2000 for a second before it calms down. im happy with it right now.
Old Dec 5, 2006
SSRcivic's Avatar
SSRcivic will become famous soon enoughSSRcivic will become famous soon enough
I got in a wreck about 2.5 months ago and just now was able to get my car started due to a dead battery. My car (2001 EX) is having the same problem with idle. It didnt have the problem before. I did have problems starting the thing. Once I got it started I just drove it around awhile and it seems when the car warms up it starts happening. When I come to a stop the idle hits 1000 and then jumps to 1500 back to 1000, repeats once more, and then goes to what it was before the car was wrecked. Is there a code that your car is throwing for your dilemma, just so I can get some idea (another of many) of what my car is doing. To clarify I got hit in my drivers side rear quarter panel so I dont see the wreck having an effect on the idle.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
usajags84
May 30, 2015 06:49 PM
Chronic_issues
May 8, 2015 05:40 PM
Ashley Farr
May 7, 2015 05:01 PM
supercivic01
South
Nov 30, 2001 11:27 AM
