Tuning day! Done
Tuning day! Done
Ok i got my **** tuned today, finally!
Tsi kit
t25
rsx-s injectors
emanage with support tool
3" exhaust no cat!
= 169whp.....at 5 psi tuned by forged perfomance
Tsi kit
t25
rsx-s injectors
3" exhaust no cat!
as soon as i get the dyno sheets scanned i will post! i got a boost spike, of course, it spikes at 7psi then drops to a steady 5psi. i need a bigger down pipe, the tsi is i think 2.5" .... but other than that its ready for some autocross!!
I wish I knew more about turbos. That way I would actually get everything needed, install it myself and beat ricers that rev at me on highway....or when im TURNING the corner and they pass me. -_-
I think I need to see the dyno sheet... I probably would have expected more, especially if you're spiking to 7 lbs with that free of an exhaust. What kind of dyno was it?
i was gonna PM you because this is a totally nooob question.....but im sure other noobs will find this helpful...i think
ok, so you have bolted on ur turbo...then what? plug in ur engine management?
then what? do u just start up the car? and it runs fine? or do u tow it to a dyno shop n let them tune it?
once you have your turbo kit on you need some sort of device that would add mroe fuel into injectors. since you got your turbo you have humongous amounts of compressed air entering your engine and if you have lots of air and no fuel = BOOM. this is called running lean. so bolt the turbo and control your fuel and you will be able to run temporarily like i have. you should really get tuned asap though its very important. you never know what can go wrong with your motor especially if its untuned.
driving at partial throttle it does hesitate but thats around 3k after that its smooth. not sure on the afr's i wasnt in the shop when it was tuned but i know its running a little on rich side!!!! 14.7 ? i wish
Oh I thought you had a wideband hooked up. That might not be a bad investment if you ever wanted to tweak your settings with a laptop on the emanage. So how's the ride you never said if you were happy or not? Does it pull hard down low with the t25?
I love driving it, i think thats bad cuz i am out of gas money!
