turbo question
Guest
Posts: n/a
turbo question
hey, i was wondering is this a good set-up for turbo?:
DESCRIPTION: 01-05 CIVIC D17 T3 TURBO KIT
Including following item
-turbo manifold D17 SOHC MOTOR
-38 mm wastegate
-godspeed SPEC A INTERCOOLER (25X6.5X3" CORE SIZE)
-t3 stage 3 turbo
-ssqv blow off valve
-oil line
-universal 2.5" aluminum intercooler piping with silicone
T3 T4 TURBO SPEC:
45 trim
2.36 inlet diameter
2" outlet
1/8 npt oil inlet
t3 flange
.42 ar compressor
.48 ar tubrine
wet float bearing
what else would i need to make this work..a emanage (i thought emange said manual only)? i have automatic, so if any of u turbo auto's have suggestions im open
-38 mm wastegate
-t3 stage 3 turbo
-oil line
T3 T4 TURBO SPEC:
45 trim
2.36 inlet diameter
2" outlet
1/8 npt oil inlet
t3 flange
.42 ar compressor
.48 ar tubrine
wet float bearing
These sounds like one of those ebay turbo kits? Besides all that hardware you def want some fuel management. Emanage will work but larger injectors you'll need for sure unless you're going to do like a TSI fuel system.
Well you should save up, or if you want it now make a custom kit. Although you will have a bunch of headaches going that route. Best way to go is save up for Dezod's kit and not go the ebay route.
BUT, nothing turbo is cheap. Down the line, plan on a head gasket, clutch, maybe a full rebuild, a tranny rebuild, etc.....
very good info boiler as always. i guess if you really want to get that kit you can get that kit just ditch the manifold, the manifold is garbage it will crack/break on you in a matter of days. my friend is running en ebay turbo set up like that with a nice manifold and it works pretty good. just know that you get what you pay for. i have learned that the hard way, buying cheap stuff having it break then buying expensive stuff to replace it. ended up paying twice on something where i could have bought once and got it over with. bottom line is dont cheap your self out too much or you will end up regretting it at the end
::smacks 05 civic lx:: How dare you? here man i got a 2005 civic lx and i bought this 1 but i have to wait until mid summer to install it b/c of money but to to www.procivic.com and look at the turbo there......nuff said
i was thinking fo the same exact thing. to get an ebay one but i do think those are crap and will break. some gonna just buy separate parts. and make my own turbo kit. this wont be for another 2-3 years. haha
that extreme turbo kit in that site you mentioned looks pretty good. thinking about buying one later. im guessing you bought the extreme turbo kit?
^^^ yea i sent you PM about turboes. whats the cheapest and safest turbo kit you got for the d17a2? and also you mentioned about the 50 dollar trans. cooler. wouldnt it be better to get the best one? meaning the more expensive one?
7thgen Power Maker
With respect to the cooler, space becomes the hardest thing to battle. Some of the more expensive ones are larger and become harder to fit. So, in this case, the smaller cheaper one works fine.
ohh...so the cheapo one will work just fine then right? and also i dont have anything that even deals with a turbo kit right now so i would probably order everything i need to make the turbo run smoothly.
7thgen Power Maker
Yes sir. I drove many of cars & trucks with the cheap coolers and they held up fine.
7thgen Power Maker
We do not include a tranny cooler, so that is fine.
7thgen Power Maker
With respect to the turbo, for sure. Our kit produced monster power on just 5 PSI!! 170whp!
Ask wilmnchris how an auto is with our kit.
those are some pretty good numbers. how many psi can go up to safely with an auto?
7thgen Power Maker
7thgen Power Maker
7PSI on a hair dryer? 7 PSI on a T25? 7 PSI on a T3/T4 57 trim? 7 PSI on a GT61?
My point is 7 PSI on each of those turbos is different because of the flow rate of them. Understand? Think in terms of power levels and/or flow rates...not PSI
well... i was talking about the t3 turbo since your kit says that it comes with a t3/t4 turbo?
ftw
that's wayyy to much power
