Throttle Position Sensor
Old Nov 10, 2006
percy_power's Avatar
percy_power is an unknown quantity at this point
I tried searching this forum for some info on this but came up with more questions. So I figured I'd just start another thread. I have a 2002 Civic Coupe LX 150,000KM. Light came on, took it in and was told it was due to the throttle position sensor. I hadn't even heard of this before so looked it up and can't find a lot of info about it. It's very expensive to fix and I don't know what to do...is the car safe to drive around while I figure this out? What does this sensor control?
Any help would be greatly appreciated. Thanks.
Old Nov 11, 2006
d17acivic's Avatar
d17acivic is an unknown quantity at this point
the car should be safe to drive. it is the sensor and black clip that is on the throttle body it should have a few wires running to it i would check to insure that the wire is clipped in and if it is in fact still throwing the code i would go to a junkyard or LKQ maybe even ebay and try to find a throttle body with a tps for a d17a1
Old Nov 11, 2006
streetglower's Avatar
well how does the car drive?
The Throttle position sensor sends a signal to the ecm of the position of the throttle plate. that way the ecm can add or reduce fuel. it also is used in conjunction with the automatic transmission. it helps with the shift points.
Old Nov 11, 2006
Took it out this morning to run errands, was OK for the first 10 minutes, engine light was off, then the light came back on. It's an automatic and it didn't want to change gears, was revving high not even touching the throttle.
Anyway, I spoke with my Honda garage over the phone and they said they would have to replace the whole throttle body, not just the sensor...how come you can't just get a new sensor? Where is the sensor located?
Thanks for the replies.
Old Nov 11, 2006
honda is correct, the sensor cant be purchased seperatley, it is part of the throttle body. Now some have said you can remove the sensor from the throttle body and replace it with one purchased from ebay, but you will have to calibrate it. Not sure if true or not.
But I had the same issue when my car was under warranty. the check engine light came on and the shifter wouldnt come out of park sometimes and I couldnt get out of first gear. it was around $270 for the part. not sure how much they charge labor, I was under warranty, but if you want to replace it yourself, just remove the air filter box and it is right there. may have to remove a few other things, but not sure.
Old Nov 15, 2006
sql_civic's Avatar
I'd offer up the '02 TB I've got laying around but it's for a 5 speed manual.
Old Nov 15, 2006
same happened to me, the auto trans wouldnt shift well if at all. i limped it home and swapped the throttle body. try and find a used one but be sure its for an auto. the manual tb will not work.
Old Sep 10, 2012
bigteddybear's Avatar
bigteddybear is an unknown quantity at this point
Re: Throttle Position Sensor
Do you still have the TB for 02 Civic 5 speed manual? I need one please let me know how to get in touch. Thanks.
Old Sep 11, 2012
nsrhonda89's Avatar
nsrhonda89 has a spectacular aura aboutnsrhonda89 has a spectacular aura about
I bought my oem tps sensor from this seller on ebay and installed it using a volt meter.
Genuine HONDA 01 02 03 04 05 CIVIC 1.7 OEM throttle position sensor TPS
http://www.ebay.com/itm/Genuine-HOND...8322b2&vxp=mtr
Old Oct 30, 2012
TheDarkKight's Avatar
TheDarkKight is an unknown quantity at this point
finally rebuilt my 1995 Honda Civic everything is running great but the idling is out of control, Already changed out the idle control valve ( brand new) went on you tube to see what else it could be? So i tired to tighten the Air control valve and nothing still? So maybe i need to change the the throttle position sensor but i watched a video ( once again) and a few guys said you have to cut off the old throttle position sensor and put new screw holes? idk from the looks of it i thought you would just unscrew the old one and and screw the new one on? Im not sure what i could be? and the person who rebuilt my engine wont answer my calls or want to to drop it off for a few day but his few days become weeks and i live in Portland Oregon and it rains to much to not have a car haha if anyone could help me out that would be GREAT!![YOUTUBE]/YOUTUBE]
Old Oct 30, 2012
mikey1's Avatar
Originally Posted by TheDarkKight
finally rebuilt my 1995 Honda Civic everything is running great but the idling is out of control, Already changed out the idle control valve ( brand new) went on you tube to see what else it could be? So i tired to tighten the Air control valve and nothing still? So maybe i need to change the the throttle position sensor but i watched a video ( once again) and a few guys said you have to cut off the old throttle position sensor and put new screw holes? idk from the looks of it i thought you would just unscrew the old one and and screw the new one on? Im not sure what i could be? and the person who rebuilt my engine wont answer my calls or want to to drop it off for a few day but his few days become weeks and i live in Portland Oregon and it rains to much to not have a car haha if anyone could help me out that would be GREAT!!/YOUTUBE]
first of all you should start your own thread, this one is years old,
what makes you think the problem is a sensor?
are you getting any codes? is your engine light coming on?
high idle could be many things, not just a sensor, it could be something as simple as your intake gaskets leaking!
Old Jul 6, 2019
bbynams's Avatar
bbynams has a spectacular aura aboutbbynams has a spectacular aura aboutbbynams has a spectacular aura about
The TPS directly affects shift points and engine idle. Replacing mine made both better, but probably something only I would notice and isn't part of routine maintenance. This is a good project if you're just learning how to use a multimeter. The throttle position sensor looks like a spring-loaded clock and moves as an extension of the throttle plate to send an electrical signal about its location. The correct range is from 0.5v closed to 4.5v WOT, which you can adjust by rotating the sensor. Green is ground (black lead) and red is the wire you want the value from (red lead) from the 20v setting on your multimeter. You can back-probe the wires with something like a safety pin. Taking off the air cleaner (four 10mm bolts and one 8mm screw on a hose clamp) and throttle body (four 10mm bolts on the throttle body, 2 clips around the IAC valve and 2 around the EVAP hoses) requires sockets with an extension and pliers for removing clips. You need your keys in the ignition with a half turn so there's power going to the sensor. The original screws are most likely riveted, so be prepared for a fight with some pliers or slotting them out with a Dremel.
Old Jul 17, 2019
Dave88LX's Avatar
Dave88LX is an unknown quantity at this point
I haven't back probe yet. But I did hook up to my ECU to see what was happening. I just put a new-used throttle body on my 2005 Civic Hybrid. I was previously having a hunting idle and wanted to eliminate the IAC or TPS.
So now the hunting idle is gone, but I do have a high idle still. I'm not sure what I can do to bring the idle down. I'm not sure if there's a good idle relearn process I can do, or if I need to bring it somewhere and have the ECU programmed.
My TPS is showing 9.4% at idle, I would think it would be 0%? WOT shows 90%.
Any thoughts? I could create my own thread too if that's better.
Old Oct 21, 2019
PatrickHall1701's Avatar
PatrickHall1701 is an unknown quantity at this point
Hello,
I am new here and I am having a problem with my 2005 Honda Civic EX. Right now it will not accelerate above 200 rpms in first gear and it will also not rev above 200 rpms in Neutral. Everyone keeps telilng it is my CAT and even though a friend of mine found a shop that would only charge 200 for parts and labor. 200 bucks is 200 bucks. I googled the problem and it mentions the throttle body sensor and other sensors I have already replaced including the upstream 02 sensor. The check engine light is on and the only code it is throwing is still showing is for the upstream 02 sensor which as I just stated I have already replaced. I am just if maybe it could be the throttle body sensor or even the camshaft sensor as a co-worker of mine suggests. Any assistance will be greatly appreciated.
Have a good day
Old Oct 21, 2019
GolNat's Avatar
Prelude Owner
Originally Posted by PatrickHall1701
Hello,
Have a good day
Did you use an OE sensor? Was the ECU reset after it was installed?
Old Oct 21, 2019
Colin42's Avatar
If you remove the front 02 sensor does that improve acceleration?
Old Oct 21, 2019
No it was not. I was afraid to drive it around the block until the engine reached operating temperature.
Old Oct 21, 2019
No why would I remove a new 02 Sensor?
Old Oct 21, 2019
OE Sensor?
Old Oct 21, 2019
GolNat's Avatar
Prelude Owner
OE as in NTK or Denso brand. Not a cheap universal one they try to sell you at the parts store for $60.
The ECU needs to be reset by disconnecting the battery so it can clear the code and go through its routine again.
Old Oct 21, 2019
Okay that could a the problem. The car has been sitting for a a while and eventually the battery was dead over a week. After i had O'Reilly's recharge the battery and I started the car again the check engine light was still on and the car still would not rev or accelerate over 200 rpms
Old Oct 21, 2019
GolNat's Avatar
Prelude Owner
If you used the wrong/junk O2 sensor it won't matter how many times you reset it.
Old Oct 21, 2019
Even though I got the 02 Sensor on amazon I made sure it could be used for a 05 Honda Civic EX
Old Oct 21, 2019
GolNat's Avatar
Prelude Owner
Was it an NTK or Denso?
I don't care what Amazon or the parts people said would fit in the hole. Honda's are very picky about O2 sensors. Do you have a link or part number?
It was the up stream sensor which is actually an Air Fuel Ratio sensor correct? The second sensor is and oxygen sensor and does a different job. They are not interchangeable.
Old Oct 21, 2019
I got what my co-workers brother who works for the local Honda dealership maintainence told me I could get.
Old Oct 21, 2019
GolNat's Avatar
Prelude Owner
Part number?
Link?
Old Oct 21, 2019
Part number?
Link?
This one
Old Oct 21, 2019
This one
And yes the new part matched the old part that was taken out exactly
Old Oct 21, 2019
GolNat's Avatar
Prelude Owner
Not the correct one. Cheap Chinese junk.
Buy a Denso or NTK brand. It will cost a pretty penny.
Old Oct 21, 2019
When your rent is 1300 bucks and your car payment is 300 bucks you go the cheapest route with guidence from a Honda maintenance guy
