Question for anybody that installed thier own cat-back exhaust...
Old Mar 17, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
How hard were the bolts on the cat to get off?
Old Mar 17, 2002
Mbow's Avatar
The 2 on the bottom aren't to bad. It's really the top one that can get you fired up. The best thing to do is to spray them liberally with wd-40 or something similar and allow it at least 5 minutes to work. I had a relatively easy time with the 2 bottom bolts because I have a ratchet that is like a foot and half long so I had extra leverage. I still groaned like a goat getting them loose though. The top I couldn't budge for the life of me. I sprayed it with some wd-40 and then smoked a cig. Crawled back under and it came loose without a problem.
Old Mar 17, 2002
Daniel420's Avatar
Daniel420 is an unknown quantity at this point
yeah... mbow's story goes for me too except minus the cig and plus a beer. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 17, 2002
pimpdakota's Avatar
pimpdakota is an unknown quantity at this point
i used my 3/8 pnematic ingersoll impact gun!! It was easy on the rear bolts near the rear suspension ! But had to use a propane torche to heat up cat bolts! If i remember right those had spring tensioners! So they would be sort of tough without an impact!! Dakota
Old Mar 17, 2002
Mbow's Avatar
The spring tensioners are in ther rear where the muffler connects to the the midpipe. Those were a piece of cake to get off. Oh yeah, pick up a tube of antiseize and put a light cote on the bolt threads. If you ever put the oem back on or need to take the system off for some reason, the bolts will be much easier to get off.
Old Mar 17, 2002
02CarbonCivic's Avatar
02CarbonCivic is an unknown quantity at this point
That was the only problem I had too was that damn top bolt.... I didnt think the wd-40 worked any.... I just finally grew some ***** and got it off
Old Mar 18, 2002
sorphin's Avatar
sorphin is an unknown quantity at this point
I had no probs what so ever, just used a lil WD, a breaker bar and some muscle (didn't take much).. went painlessly [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
-ds
masongap
May 26, 2015 07:55 PM
pincookie1
May 4, 2015 12:22 PM
bsmiley
Apr 27, 2015 01:27 PM
viper775
Nov 8, 2001 09:14 PM
