01 civic car shakes
Old Oct 26, 2006
hcivic0120's Avatar
hcivic0120 is an unknown quantity at this point
01 civic car shakes
i have a 2001 honda civic ex and at idle espeically and driving the car shakes through out the whole car dash, shift ****, seats and steering wheel noticeable the most? its not a real bad vibration but just enough to annoy you. I'm guessing its motor mounts or exhaust, but i did check the motor mounts dont seem bad, and couldn't see anywhere where the exhaust is making noise or touching the car that i could be able to see? Anyone got ideas y or solutions to fix this problem? I would appreciate it a lot.
Old Oct 27, 2006
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
Auto or manual? Did you look closely at the front motor mount? Try to shine a flash light down to see if it’s cracked.
Old Oct 28, 2006
hcivic0120's Avatar
I looked at the motor mounts a little bit. Where are they all located at? and i see one that is right by the timing belt, as soon as you open the hood, on the top right side, the rubber thing is cracked, torn up could that be the problem?
Old Oct 28, 2006
dopes6070's Avatar
There is a front mount, 1 mount on each side and one rear. If the rubber is cracked it will shake. Chances are if one of your side mounts are torn, the front and rear ones are bad too.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Markias
Detailing
Nov 4, 2001 05:15 PM
AL
Oct 18, 2001 03:01 PM
mj1010
Aug 26, 2001 09:52 PM
eXNBP
Aug 7, 2001 11:50 PM
