double start anyone???
Old Oct 25, 2006
qgt_racing2000's Avatar
qgt_racing2000 is an unknown quantity at this point
hey guys,
its been happening for awhile now.. sumtimes when i go to start my car, it wont start.. i have to turn it to "off" and then turn it to "on" position and wait til it stops beeping and all the lights settle, then i can start it with ease...
does anyone know why this is happening? i dunt have much hooked to my battery.. i just have HIDs connected to the battery, and two 6" neons connected to my cig lighter... and a RSM to the ECU, and thats about it...
do you think if I did they battery "Grounding", it will help???
thanks for looking guys....
Old Oct 25, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
Ive also had this problem in the past, Even had my car stall at a intersection for no reason and started up fine. I would also like to know.
Old Oct 26, 2006
streetglower's Avatar
Originally Posted by qgt_racing2000
hey guys,
the way you described it sounds like you have fuel bleeding off somewhere. If this happens everytime you start, I would suspect a component leaking. like a fuel injector or fuel bleeding back into the tank. turning it on and waiting you are energizing the fuel pump for a few seconds thus putting fuel back into the rail.
Old Oct 26, 2006
this doesnt happen all the time, but every now and then... how bad is it? my car is off warranty.. its an 02'
Old Oct 27, 2006
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
probably the immobilizer. check to see if a little green key shaped light on the dash flashes as you are cranking it.
mugenca
Apr 16, 2015 12:15 AM
LJ
Dec 10, 2001 10:48 AM
black2k1vtec
Dec 6, 2001 09:49 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
Mokushi
Nov 1, 2001 02:40 PM
