Antifreeze Coolant EXPLOSION
Old Oct 14, 2006
401CivicLX's Avatar
401CivicLX has a little shameless behaviour in the past
Exclamation Antifreeze Coolant EXPLOSION
hey guys,
today, i put about 3inches over the MAX line of antifreeze in my car..... what kind of damage willl this create?? I'm a bit worried... I'm sure most of you guys have a 7th gen civic... it's freakin hard to see the damn MAX/MIN!! i wouldn't worrry if it was like 1cm over... but it is 3 inches.......
Old Oct 14, 2006
robbclark1's Avatar
Retired suspension supermod.
Originally Posted by 401CivicLX
hey guys,
you're fine just check to see if it overflows occasionally. If it does, clean it up to protect animals and little children. don't worry, mine is currently overfilled and I don't have a problem.
Old Oct 15, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
Or just drain some of it out. Should be a white plug somewhere under your front bumper.
Old Oct 15, 2006
robbclark1's Avatar
that won't drain it from the resevoir
Old Oct 15, 2006
tfnaaf's Avatar
BLDNPSI Mod
call Homeland security and step away from the car
Old Oct 15, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
or go to the dollar store and get a turkey baster..
Old Oct 15, 2006
robbclark1's Avatar
+rep for jooo
Old Oct 15, 2006
nothing will happen
Old Oct 16, 2006
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
since our cars (like most common cars nowadays) have a closed cooling system, it is basically designed to catch any expanding/overflowing coolant that system cannot handle. Just make sure you dont have it topped off because you still need some room for expansion. But you should be fine..
Old Oct 17, 2006
dalaw's Avatar
Bone Stock!
the coolant will just spill out from the top if it does get that high. No worries.
styles234
21
Nov 19, 2019 07:23 AM
cferry7
Oct 3, 2015 04:33 PM
raymondxcho
Sep 29, 2015 09:00 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
