brakes question
Old Oct 3, 2006
jonjon81's Avatar
jonjon81 is an unknown quantity at this point
brakes question
ive owned my civic for a lil over a year..and 2 months ago i would hear a nosie when i apply the brakes...sooooo it was time for a brake job..and the sound went away...however it came back maybe a week ago..and i know for a fact the brakes are good!!!...its kinda hard to explain the noise online .. but why would it go away with a new brake job..then come back?
Old Oct 3, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
maybe if its not the brakes...
try explaining the noise and when it happens and what yer doing at the time (driving, stoping, inching foward at a stoplight, ect)
Old Oct 3, 2006
phuviano's Avatar
Slowest 7thgen in the GTA
Try putting on some brake grease on the side of the brake pads. That could be causing your noise.
Old Oct 4, 2006
streetglower's Avatar
just because you did the brakes a few weeks ago doesnt mean a brake noise wont come back. its possibly a pebble or something got lodged in between the pads and rotors. you need to check everything again.
Old Oct 4, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
Is it squealing? If so, thats nothing to worry about. It's just annoying. Sqealing is "normal" at low speeds, its from pad vibration. At high speeds is a different story.
Old Oct 4, 2006
russo-r34's Avatar
russo-r34 is an unknown quantity at this point
could be the time to replace your rotors
Old Oct 4, 2006
jonjon81's Avatar
i only hear the noise when im slowing down to almost a compelte stop
Old Oct 4, 2006
jonjon81's Avatar
had em turned with the 1st brake job
Old Oct 4, 2006
jonjon81's Avatar
yea i thought of that earlier..but i do remeber putting some on..maybe not enough?
Old Oct 4, 2006
jonjon81's Avatar
you may be right ..atleast im hoping so..i dont ever hear it on the free-way when i slow down...just at low speeds.
Old Oct 4, 2006
jonjon81's Avatar
this is true
Old Oct 4, 2006
jonjon81's Avatar
thanks to everyone for taking the time to give me their thougths...ill be sure to take them all into consideration.
Old Oct 13, 2006
mrb420's Avatar
mrb420 is an unknown quantity at this point
I have the same issue!!!
I am experiencing the same thing with my 2002 civic.
When I am braking slowly, like in bumper to bumper traffic, my brakes make this loud creaking noise. I plan to pull off the tires and inspect the brakes this weekend.
I hope we can find the solution to this annoying problem.
JonJon81,
If you find the fix, private message me....
If I figure it out, I'll message you with the details...
-MrB
Old Oct 15, 2006
mrb420's Avatar
Update....
So, today I went throught the procedure for replacing the brake pads. I basically cleaned the caliper assembly with brake cleaner, took out the pads, cleaned the reatiner clips, inspected the pads, rotor and caliper assy; then put everything back together. I used a 'caliper' to measure the thickness of the rotors. Both rotors were about 20mm thick. I tried to read the stamp displaying the minimum thickness, but it was very hard to read. I am pretty sure I should replace the rotors as soon as possible.
Anyone know the minimum thickness for stock rotors (i think it said 19mm)?
Anyone know how thick new rotors usually are?
Anyway, I didn't notice any problems, other than the thickness. So, I will see if my problems still exists, and keep sumitting updates.
Old Oct 16, 2006
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
i dont off hand know the minumum thickness but tomorrow at work i will check for ya.
Old Oct 16, 2006
andwong's Avatar
andwong is an unknown quantity at this point
Well I just bought a pair of new disc and brake pads. Anyone know how to DIY ?
Old Oct 16, 2006
mrb420's Avatar
Here ya go...
Check out the link below. It is from the "7th Gen Honda Civic Do It Yourself Articles" subforum in the "Tech Chat and DIYs Forum"
.............D.I.Y. Link..................
Old Oct 16, 2006
jonjon81's Avatar
mrb420
i still hear it..and im not sure whats going on...other than the noise..the car itself handles fine .. stops fine..no problems
Old Oct 17, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
As per the Service Manual:
Standard thickness 20.9 to 21.8 mm
Max refinishing limit 19.0 mm (meaning will not resurface if less than 19)
7thgensurvivor
38
Aug 29, 2015 11:50 AM
masongap
May 26, 2015 07:55 PM
bsmiley
Apr 27, 2015 01:27 PM
viper775
Dec 9, 2001 10:52 PM
