Just got my car dyno'd..
Old Sep 10, 2006
well, got it back last weekend, just got around to putting all this up.. They installed an AEM UEGO a/f controller, fixed some parts of the turbo/manifold, and dyno tuned.. apparently i have a massive leak in the turbo and it can only boost a max of 2-3psi.. i'm prolly gonna ditch the SF mani and old turbo and get a new one.. we'll see what happens..
here's my setup:
SF Turbo kit (Ditched the SF FMU)
-garrett t3 super 60
-SF IC and plumbing
-Random Technologies Hi flow cat
-APEX'i WSII exhaust
-RSX-S Injectors
-APEX'i VAFC-II (i know.. not the best to tune with, but its what i had.. i'm gonna save my money and go all out with an AEM EMS)
here's the chart.. i'm a complete n00b when it comes to reading this, so any input would be greatly appreciated..
The horsepower seems correct for the mods, but the torque is pretty crazy.. i HIGHLY doubt i'm running 594.9 ft-lbs of torque.. lol.. i've looked into the SAE correction factor and since i suck at this game, i cant figure it out.. apparently it was about 72ºF that day, but i cant find any atmospheric pressures associated with that day..
I'm also throwing a P0172 CEL... how do i fix that..?
Old Sep 10, 2006
Logan3024's Avatar
p0172 is means your getting to much fuel while your in closed loop, pull back some fuel in your narrow throttle position on the Vafc, Gotta love odb2! Other wise your numbers look about right, i normally figure about 8-10 whp for every 1 lb of boost unless your running a huge turbo. Be sure to let me know when you get back to Vegas, thats gonna make about 5 of us running around here.
GOOD LUCK~!
Old Sep 10, 2006
my car's gonna be back in vegas in mid-october or so.. i'm leaving it with my dad and sister when my ship goes on deployment
Old Sep 10, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I think the dyno read outs are very wrong.
140whp on 2-3 psi?
That's a little too optimistic
Old Sep 11, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
i have to agree...something looks very wrong there....
Old Sep 11, 2006
C2i0v0i1C's Avatar
SuperMODrizd
590 on torque, christ all mighty i bet u twisted the chasis while on the dyno
Old Sep 11, 2006
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
lol liquified everything else!
Old Sep 12, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
hey logan dont forget about me lol
Old Sep 12, 2006
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
140whp on 2-3 psi?
How??? He went from 127-143 if you figure 10hp for each lb of boost...at 2 lbs that'd be 147...If anything it should be higher.
Old Sep 12, 2006
I'm not sure if it is LX or EX, but stoch whp rages anywhere from ~100-115 whp. 127whp represents the lowest hp attained during one of the dyno pulls and 147whp is the highest.
1psi = 10hp very wrong, dont use this formula if you can.
Smaller turbo will yeld less psi, than a larger turbo under the same psi.
For example, just imagine C6 vette runnig 5psi of turbo boost, doest it mean its engine has 450hp? No, most likely more.
I run 9spi on a smaller turbine and I wend from 113whp stock to 175whp.
Old Sep 12, 2006
dezod's Avatar
7thgen Power Maker
This an auto?
Old Sep 12, 2006
Logan3024's Avatar
If your getting 6.8 whp (per lb) from a TINY t25 , how is "VERY WRONG" to think that a t3 super 60 will give 8-10 whp?
With that same turbo, assuming the same gains from 2-3 psi he would be around 175 at 6 psi, while your t25 makes 175 at 9 psi
And who said anything about a c6 corvette? he has a d17! Who would put a t3 super 60 on a vette anyways?
I know, i seen you smoke some dude at the races saturday night
Old Sep 12, 2006
exturbo6's Avatar
he did say it was a EXAMPLE using the vette....
Old Sep 12, 2006
Thank you for pointing this out.
Old Sep 12, 2006
exturbo6's Avatar
Hey! anytime!
Old Sep 12, 2006
Originally Posted by dezod
This an auto?
nope.. 02 ex manual tranny
Old Sep 12, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
**** seems way out of wack...
Old Sep 12, 2006
mattyg23's Avatar
mattyg23 has a spectacular aura aboutmattyg23 has a spectacular aura aboutmattyg23 has a spectacular aura about
how much does it cost to get a car dynoed?
Old Sep 12, 2006
C2i0v0i1C's Avatar
SuperMODrizd
100+ an hour
Old Sep 18, 2006
Thanks for negative rep!
"Another a$shat comment. Just STFU next time."
Why not to leave your name and accept full responsibility for your comments?
Is it because you understood that you were not right and refused to accept it?
Old Sep 18, 2006
SLO REX's Avatar
250+ awhp Stage 2
100+ an hour
Most places are around $100 an hour or 3 runs for $50 unless they have a group day of dynoes and usually you can get 3 runs for around $25-$30
Old Sep 18, 2006
Civicman1988's Avatar
you are so right on that
Old Sep 20, 2006
so what was the verdict?
Old Sep 20, 2006
SLO REX's Avatar
250+ awhp Stage 2
Chassis twisting power!!!!1!1!!11!11
Old Sep 21, 2006
where did you get your can dyno'd? you should probably invest in emanage. i dont know much about emanage and neither does many tuners out in vegas but i hear that lots of locals like logan know a lot about emanage. im just about ready to hook my emanage up
Old Sep 21, 2006
02BLKCIVIC's Avatar
Sooooo no new word on the record breaking TQ #'s???
Old Sep 21, 2006
v8eaterokv6's Avatar
i have a new home do u
when my turbo wasnt working right on the dyno i was putting out about 2psi and was getting about 102 hp that was with e manage tuned so i dont see how your gettin 140+ with 2-3 psi
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
dubbc
Nov 7, 2001 02:24 PM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
