how do i get 12v output from PC ?
I need TP for my bunghole
i saw that but i dont think it will work for me
here this is wat i wants to do
for my retrofit i need to connect ballast to pc or to wall jack to test out my aim them...
Get a male replacement plug end for an extention cord from the hardware store and temporarily wire the ballast to that so it can be plugged into the wall.
NO NO
do not do that...http://www.cluefree.com/technical/pc...connectors.htm
Peripheral DC Power is what you are looking for...
Use the link to connect 12V and GND pin to supply to your ballast...Just unplug unused pins by carefully pulling out...for safety...use the pic
Wall outlets are 120V AC not DC...
also use some resistor to limit the current to the ballast....this is a must...12V/resistor = current you want..
this number depends on the ballast....use what ever number is on the spec sheet...
Yellow and BLK are the wires that you want to use..
I attached a spec sheet for a Power Supply Unit from Antec...
U have one that should specify the rating like this...
it says the min is .4A to max of 19A..for +12V supply
Its hard to tell because I dont know what PSU you have...
What is the rating on the ballast...is there a minimum current that it needs?
susuking
u don't need a resistor, the amp is too small anyway
h4ldol
Apr 24, 2017 08:16 PM
Elciteeve
Sep 28, 2015 12:40 PM
JMKendrick
Sep 16, 2015 06:17 PM
tomas6791
Sep 11, 2015 06:47 PM
Bricoleur
Sep 9, 2015 12:23 PM
