problem.
Old Sep 5, 2006
fakitzjason's Avatar
fakitzjason is an unknown quantity at this point
problem.
heyyy guys i finally found the problem about my headlight switch. some1 broke into my car and snapped my headlight switch in half soooo all it is right now is dangaling by the wires. they cut the black wire which was the ground i guess. but ya. can some1 show me how to re-wire it. its a bitch cuz the other half of the wire is where the steerin wheel is at and its in a really tite space. can some1 help me do it? thank u!
Old Sep 5, 2006
CraigW's Avatar
The black is the ground. You could try to use a razor blade to strip the insulation from the wires and re-connect (if you have enough wire showing) you could also run a new ground up to the black wire going to the switch.
As far as a replacement switch I suggest www.cheapesthondaparts.com good prices and cheap shipping.
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
260000milesgoal
Sep 25, 2015 07:41 PM
IronFist
Sep 25, 2015 07:13 PM
Skunkone
Sep 24, 2015 04:38 PM
curaze
Sep 22, 2015 08:27 AM
