easy to swap head units myself?
Old Sep 5, 2006
sf2ryu's Avatar
sf2ryu is an unknown quantity at this point
I have an Aiwa head unit, but I want to swap it with a Pioneer head unit that I took off my old car. Circuit city had done the Aiwa install before, so the dash kit is already in there. For an electrical newbie like myself, would it be easy for me to swap out the head unit if I were to buy the right wire harnesses? Would everything just be plug & play or would I have to do some splicing? What would be involved?
Old Sep 5, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
no matter what you gotta do some splicing but its not hard at all, if you can see colors, read, and use a crimper (better to soilder SP? but not everyone can) then you are set
Old Sep 6, 2006
WhiteRabbit's Avatar
a pretty simple job. the cage is crimped in, easy to uncrimp and remove. the pioneer one is specific for pioneer, and will need to be installed.
that takes care of physical install, minus radio bezel removal, which can be found here in the DIY. short answer is once the two bolts that hold in the radio bezel from underneat are removed, it pops right out, easy.
the wiring is cake. if circuit city did their job right, youve got a wire harness in your car. its a set of wires with two plugs. one plug fits your stock harness, the other the aiwa radio. for you, its as simple as cutting that harness in half and splicing in the pioneer harness where the aiwa one was. the colors will match up perfectly.
easy peasy.
Old Sep 6, 2006
Anathema's Avatar
The internet says Im a loser
Anathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of light
easy peasy.
^ Well said
As a side note. When I installed my Pioneer head unit, instead of splicing the wires together I put male/female connectors on each wire incase I ever needed to remove the head unit all I had to do is remove the Pioneer harness from the connectors and install the new harness to the existing connectors. Just an idea I had for future expansion. You never know what will happen
Old Sep 8, 2006
honda983's Avatar
honda983 is an unknown quantity at this point
it is easy just like he said if u are not color blind it will be easy. the face should slid into the sleve with the car kit good luck
Old Sep 20, 2006
sf2ryu's Avatar
cool that sounds easy. I think that will give me the confidence to take it apart and swap the head units. Thanks all!
4 banger
Jun 5, 2015 01:44 AM
mugenca
Apr 16, 2015 12:15 AM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
