Best polyurethane bushings
Old Sep 3, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
I am swapping out my trans for another 5spd. Mine died. Both compliance bushings are shot on either side and so are the motor mounts. What are the best polyurethane bushings to replace mine with. Thanks alot.
Old Sep 3, 2006
BlackKnight008's Avatar
420 Member
BlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura about
cough search cough
Old Sep 4, 2006
jamesandrew58's Avatar
Super Member
jamesandrew58 is an unknown quantity at this point
try energy suspension
Old Sep 15, 2006
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
if you are getting polyurethane bushings get ready for a really noisy uncomfy ride, the car will rattle like a b!tch on take-off, but it'll be more responsive. I have the black energy suspension ones on my car. g luck
Old Sep 16, 2006
Axxe's Avatar
Axxe is an unknown quantity at this point
^^ Also, when I was installing MrXclusive's bushings I had to modify them a bit just to make them fit! The mold for them must be sloppy, as they were rough around the edges and did not want to slide into the gaps on the stock bushings.
On a side note, you need to change your driving style if you killed a manual transmission and the bushings.
Old Sep 16, 2006
Hurts2bStock's Avatar
Shinier than yours, meatbag
With our transmissions?.....lol...you mean change your driving style to not driving at all
Old Sep 16, 2006
Axxe's Avatar
Well, he still killed the bushings, and I know Mr Xclusive is an aggressive shifter. Then again, I find that the 7th gens have poor build quality all over. With that said, the manual tranny in my E30 has just over 500,000 kms on it, and shifts butter smooth. It's just a bit noisy at idle (typical roar of all older Getrag transmissions). Guys in Europe run 800 hp turbo monsters on stock transmissions!!
ThatGuy913
Sep 28, 2015 05:35 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
czarlun
Sep 14, 2015 08:16 PM
