Stereo Shutting Off
Old Sep 3, 2006
Flip_Si's Avatar
Flip_Si is an unknown quantity at this point
Unhappy Stereo Shutting Off
This has been happening to me for a couple of weeks now. I have a Pioneer DEH-P7200 HU that has been installed since the beginning of the year. Once in a while while I'm driving, the stereo shuts off and I can't turn it back on. Usually about 30mins later I can turn it back on and I have to reprogram all of my radio stations and the clock. The last time it happened, the A/C turned on and it took over an hour to be able to turn back on the stereo. Everytime this happens I only have the volume at 2/3rd loud. I'm running all stock speakers with no amps. Anyone have a clue what is going on?
Flip Si
Old Sep 3, 2006
well if you have to reset everything, then it was installed wrong. either the power wires are loose, or you have a problem with your battery or grounding. ive never heard of a pioneer having heat problem, so im gonna stick with bad install.
Old Sep 3, 2006
jayo2's Avatar
jayo2 is an unknown quantity at this point
Smile
I agree with Gearbox, it sounds like a loose wire. If you used a wire harness, check to make sure the wires & pins are pushed all the way in. The yellow wire is usually the one that has a direct connection to the battery so that you don't loose all your presets Etc. I have a feeling that it is going to be a loose connection where the wiring harness plugs into the headunit. If it's not tight a bump could cause it to loose connection & another bump(or pounding with your fist) could bring it back on.
Old Sep 3, 2006
4Saris's Avatar
4Saris is an unknown quantity at this point
Reinstall it from step one. I think it's a bad ground wire or cold solder.
Old Sep 3, 2006
Rennen's Avatar
New Mod on the Block
my pioneer used to do that too... it hasnt done it in a while though... i just pulled everything out and sodered all my wires together.
Old Sep 3, 2006
ya also make sure connections are covered. stupid me wrapped tape around the power wire but the wire poked through and touched a ground plate haha. good thing deck wasnt plugged in yet.
Old Sep 3, 2006
Flip_Si's Avatar
When I installed it. I solder all the wires to the wire harness and put electrical tape over the solder wires. But I remember that I had to shove in the deck because I didn't cut the wires short enough to fit it all in. I guess I'll have to pull it out and start over.
Flip Si
Old Sep 3, 2006
just make sure everythings taped up
Old Sep 3, 2006
Flip_Si's Avatar
Thanks everyone for the reply. I just found it strange that the A/C would turn on when my HU shuts off.
Old Sep 3, 2006
hmm lol something is screwy with the wires. are you sure you didnt wire it to the ac or what
Old Sep 4, 2006
4Saris's Avatar
I'm not exactly sure how it works, but when you have a cold solder, the source (your HU) looks for another place to ground itself. Now, I don't think that there are any power connections for the two, but if the A/C is assisting in that, it may turn on. This happened with my alarm where it would roll down the window when I armed it.
SammySC
121
Apr 7, 2017 07:43 PM
solarpunk70
Apr 12, 2016 11:43 AM
Solo Flow
Oct 4, 2015 07:52 AM
zeshan7616
Sep 15, 2015 12:24 PM
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
