Stereo Shutting Off
This has been happening to me for a couple of weeks now. I have a Pioneer DEH-P7200 HU that has been installed since the beginning of the year. Once in a while while I'm driving, the stereo shuts off and I can't turn it back on. Usually about 30mins later I can turn it back on and I have to reprogram all of my radio stations and the clock. The last time it happened, the A/C turned on and it took over an hour to be able to turn back on the stereo. Everytime this happens I only have the volume at 2/3rd loud. I'm running all stock speakers with no amps. Anyone have a clue what is going on?
Flip Si
Flip Si
well if you have to reset everything, then it was installed wrong. either the power wires are loose, or you have a problem with your battery or grounding. ive never heard of a pioneer having heat problem, so im gonna stick with bad install.
I agree with Gearbox, it sounds like a loose wire. If you used a wire harness, check to make sure the wires & pins are pushed all the way in. The yellow wire is usually the one that has a direct connection to the battery so that you don't loose all your presets Etc. I have a feeling that it is going to be a loose connection where the wiring harness plugs into the headunit. If it's not tight a bump could cause it to loose connection & another bump(or pounding with your fist) could bring it back on.
ya also make sure connections are covered. stupid me wrapped tape around the power wire but the wire poked through and touched a ground plate haha. good thing deck wasnt plugged in yet.
When I installed it. I solder all the wires to the wire harness and put electrical tape over the solder wires. But I remember that I had to shove in the deck because I didn't cut the wires short enough to fit it all in. I guess I'll have to pull it out and start over.
Flip Si
Flip Si
Originally Posted by Flip_Si
Thanks everyone for the reply. I just found it strange that the A/C would turn on when my HU shuts off.
solarpunk70
Apr 12, 2016 11:43 AM
zeshan7616
Sep 15, 2015 12:24 PM
