Lug bolt twisted off
Old Aug 30, 2006
ccarbo's Avatar
ccarbo is an unknown quantity at this point
Hi, I had a bad valve stem on my tire so I got it fixed and had the donut on it just to run around. Well I was taking the lug nuts off and this one would turn a few turns and then just locked. Could barely turn it loose or tight so I just had to keep trying to turn it to loosen it. Well the lug bolt snapped off !! Is that a standard bolt or a metric one? How does one put a new bolt on there? Does the rotor have to come off? Would like to do it myself if it isn't too much work to replace the bolt. Suggestions? thanks..... hope my bad luck is done.
Old Aug 31, 2006
streetglower's Avatar
happens all the time with honda. I have had about 8 so far snap on me. Just buy a new wheel stud from honda or a auto parts store. For the front, the wheel hub needs to be removed in order to replace it. on the rear, it can be easily knocked in.
Old Aug 31, 2006
ccarbo's Avatar
really, how hard is it to get the wheel hub off? Does the brake caliper have to come off. Should I just get a new lug nut or have them tap the broken bolt out of it. thanks.
Old Aug 31, 2006
CraigW's Avatar
Need a puller to remove hub.
I would replace all 4 studs at the same time while you have it off.
Old Aug 31, 2006
ccarbo's Avatar
OK, thanks for the info.
another question. Is this thing safe to drive with one lug broke off ?? The other 3 are good and tight. I work about 40 miles away and would get it fixed there. if not I will have to wait and find someone local. thanks
Old Aug 31, 2006
Anathema's Avatar
The internet says Im a loser
Anathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of light
It is safe. But It might mess up the 2 studs next to the missing stud. If there is enough left of the stud see if you can get a tuner lug over it, I was able to do that on mine. There is a DIY with pictures here if you feel you are mechanically capable of doing it yourself, I was and have had no problems with my new wheels.
Old Aug 31, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
How bad is the lug broken off? Is there any part left on it? JBweld is the ****.
Old Aug 31, 2006
Anathema's Avatar
The wheel studs are like $2 at Advanced Auto. I just replaced them Cost like $8 to replace all the ones that broke on mine and about an hour of work. Just make sure you have all the tools on-hand before you begin. Thats what took all the time for me.
Old Aug 31, 2006
wait, did you break the stud or the lug?
Old Aug 31, 2006
Anathema's Avatar
From the description in his first post, it sounds like the wheel stud.
Old Aug 31, 2006
ccarbo's Avatar
We can put this to rest.... I got my auto mech. buddy to fix it for me..... thanks for all your info guys!! Great site for info.......
Old Aug 31, 2006
Anathema's Avatar
Congrats!
How much did it cost you? If you don't mind me asking.
Old Aug 31, 2006
ccarbo's Avatar
I will post that tonight.... he's doing it today.
Got my rod back tonight..... costed only $32. That was a new bolt and the lug nut. Back on the road.
Originally Posted by Anathema
Congrats!
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
Mc7602
Sep 17, 2015 02:01 PM
siliconvalley
Sep 15, 2015 09:48 PM
