any alternative to missing link check valve??
Old Aug 24, 2006
asadrana83's Avatar
asadrana83 will become famous soon enoughasadrana83 will become famous soon enough
Hey guys...i`ve got almost everythng required for boosting my ride...the only thing left is the missing link check valve for the MAP sensor...but i cannot find it in my town currently...its going to take couple of days if i order now...so i was wondering if there is any alternative solution to the "check light" problem
Old Aug 24, 2006
andyman97's Avatar
Turbo Guru
Yeah, most auto parts stores carry one way check valves. Get 3 or 3 and run some vacuum t's, connect them together and run the check valve off the ends in series, then plug it into the manifold and plug the map sensor on top. Does the same thing.
Old Aug 24, 2006
asadrana83's Avatar
hmmm...thanks dewd...think i get what you are trying to tell...just found a pic which is close to the discription you have given...but dont you think that boost will be leaking from these check valves?? (check valves are basically one way pressure release valve right??)
Old Aug 24, 2006
asadrana83's Avatar
da pic
Old Aug 24, 2006
andyman97's Avatar
Turbo Guru
no, that isn't how they work, the holes are so small, they just don't allow the map sensor to see anything above atmosphere
Old Aug 24, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
^^^i thought that this was how the check valves are setup
Old Aug 24, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
If you're in N.America, then just contact Dezod to have him sent you missing link with next day delivery.
Missing link is far reliable to "Chek valve" thing.
Old Aug 24, 2006
andyman97's Avatar
Turbo Guru
^Not true. I ran the check valves for months. Never had any issues with them whatsoever.....
Old Aug 24, 2006
I was going to have check valves too, but ended up with ML.
For me it has less connections and lesser chance for a potentioal leak.
Bottom line, whichever is easier for you - go for it.
Old Aug 24, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
my ml sucked, it crapped out in 3 months comptech also has a map signal clamp for hondas, emanage will do it too.
Old Aug 26, 2006
tfnaaf's Avatar
BLDNPSI Mod
here is another option.... other then e-manage (what i use)
http://www.splitsec.com/products/vc1/vc1ds.htm
Old Aug 27, 2006
This is a very good product.
On the paper it looks better than missing link.
I think your problem with ML was that you are running too much boost for ML to operate properly.
It worked great at 6psi on my little t25, but at 9psi it couldnt clear preassure fast enough without me modifying it a little bit.
Last edited by 03-Acura-1.7-EL; Aug 27, 2006 at 09:04 PM. Reason: Automerged Doublepost
Old Aug 28, 2006
dezod's Avatar
7thgen Power Maker
It worked fine for me when I was running 9 PSI on my T3 Super 60
usajags84
Apr 10, 2015 09:54 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Micks2K1
Dec 6, 2001 07:09 PM
delacampos
Nov 7, 2001 09:18 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
