Kpro tune
El Pinche Turbo Mexicano
Kpro tune
Anyone have a Kpro tune i can borrow almost near finishing my swap and here is no one here that can tune, so i whant something very close to what im going to have so i can experiment a little with out riscking the engine
my setup would be
k24a1 block
k20a2 head
DC race header
Type S 6-Speed
2.5' custom exhaust...
any help would be apreciated...
thanks...
my setup would be
k24a1 block
k20a2 head
DC race header
Type S 6-Speed
thanks...
spell check pwns you
there are a few with k swaps, but they will prob say u should tune it yourself. but may be a bog prob for you if you cant find anyone, good luck. there should be a k swap thread. search it and you will find them.
run a tsx base map
big thing with that combo is revving. how high do you want to rev? obviously you won't need to take it up to 8000 rpms (you can't anyways), but 7000? 7500? run hondata's program for a tsx, they've optimized cam angles a lot already, add some fuel, keep the rpm's reasonable and have a blast
^^^No use a base map for as sort of time as possible. i was running way lean when I used the base map. I would find someone who could tune good it is really worth it. Good idea though to add fuel, if it was that simple with Kpro
beanhead
Sep 24, 2015 12:04 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
