Kpro tune
Old Aug 11, 2006
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Kpro tune
Anyone have a Kpro tune i can borrow almost near finishing my swap and here is no one here that can tune, so i whant something very close to what im going to have so i can experiment a little with out riscking the engine
my setup would be
k24a1 block
k20a2 head
DC race header
Type S 6-Speed
2.5' custom exhaust...
any help would be apreciated...
thanks...
Old Aug 11, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
PM hondaluver or lover cant remember. Search for both.
Old Aug 12, 2006
tuner04civic's Avatar
spell check pwns you
there are a few with k swaps, but they will prob say u should tune it yourself. but may be a bog prob for you if you cant find anyone, good luck. there should be a k swap thread. search it and you will find them.
Old Aug 12, 2006
Problem is i live in mexico and really would like to start from 0 so i would like a tune and then try to tune over that on a dyno...
Old Aug 12, 2006
doubledeuce2k2's Avatar
run a tsx base map
big thing with that combo is revving. how high do you want to rev? obviously you won't need to take it up to 8000 rpms (you can't anyways), but 7000? 7500? run hondata's program for a tsx, they've optimized cam angles a lot already, add some fuel, keep the rpm's reasonable and have a blast
Old Aug 13, 2006
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
^^^No use a base map for as sort of time as possible. i was running way lean when I used the base map. I would find someone who could tune good it is really worth it. Good idea though to add fuel, if it was that simple with Kpro
Old Aug 16, 2006
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
would not recommand a base map, since he is running a type-s head. Try k20a.org / clubrsx.
UltraHDGames
Jun 8, 2016 05:16 PM
shadowfist
Oct 18, 2015 02:38 PM
beanhead
Sep 24, 2015 12:04 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
