vtec help
Old Aug 5, 2006
Menace303's Avatar
Menace303 is an unknown quantity at this point
vtec help
i have a 03 ex 5 spd and the vtec only kicks in once in a while. the car was in an accident about a year ago and it was repaired by a qualified shop. i could always feel the vtec before the accident but now it might kick in @ 4500 to 5000 then stops, then again it kicks in for a few rpm then shuts off again? i took it to honda and they said they didnt find anything wrong, i know its jacked up though. also, my clutch creaks when i puch it in and realease it. any help would be appreciated. thanks.
Old Aug 6, 2006
cdmx's Avatar
well if you find out you need a new vtec solenoid then buy mine!
good luck
Old Aug 22, 2006
civydcex's Avatar
civydcex has a spectacular aura aboutcivydcex has a spectacular aura aboutcivydcex has a spectacular aura about
You have a VTEC-E motor. Vtec activates at anywhere from 2500 to 3000 rpms. It was never kicking in at 4500 it cant. You were feeling the powerban of the motor. We dont have the cam for high rpm activation. Your thinking you got a SOHC VTEC motor but you have a SOHC VTEC-E economy version!! Which is the only version we have in America. Goes from 12 valve economy mode to 16 valve mode when vtec is engaged around 2500 rpm's. About the clutch mine does that to and you could probably grease the clutch pedal backside or spray some WD40 on it. I think there is a d16w8 wich is a 3 stage Vtec. Its like ours but does kick in to high cam vtec mode. But thats over in the phillipenes or somthing. Good luck!!!
Elciteeve
Sep 28, 2015 12:40 PM
Dave Brabant
Sep 27, 2015 09:43 PM
beanhead
Sep 24, 2015 12:04 PM
chiquita.banana
Sep 24, 2015 09:42 AM
Dave Brabant
Sep 12, 2015 08:39 PM
