wheels humming....and tuner lug question!!
Old Mar 8, 2002
pounds's Avatar
pounds is an unknown quantity at this point
wheels humming
what is this about??? around when i hit 40mph...they start humming......kinda annoying.....havent tried it past 50.....hope it doesnt get worse.
oh and the place i bought from didnt send special tuner lugs......i bought konig tantrums!! do i need em for these wheels???? the shop put my stock lugs on........
could this be the reason for the humming?? do i NEED tuner lugs???
do i have bad tires?? not enough air?? or what??
Old Mar 8, 2002
avenger's Avatar
avenger is an unknown quantity at this point
my civic with parada tires hummed at 40, but that was because the tires were awful
the humming sound can also be attributed to a bad wheel bearing...
what tires ya runnin?
Old Mar 8, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Yeah, you should be running tuner lugs. You cannot run stock lug nuts with aftermarket wheels. Almost all aftermarket wheels are cone ends, while the stockers are ball ends. Also check to see if your wheels have plastic rings on the front wheels. These help install the wheel straight on the axle. Lastly, humming is most likely the cause for an out of balance situation. Are all the weights on the wheels. It is almost impossible for a wheel and tire combo to be prefectly balanced without weights.
Where did you buy them from? I had an evil experience that resulted in many of these same problems.
Old Mar 8, 2002
zappa's Avatar
zappa is an unknown quantity at this point
Wow they got the stock lugs on those wheels? Mine didnt have room for the socket to fit. Anyway get tuner lugs. I run toyo proxes Fz4 205 40 17 and they hum occasionally but it depends on the road surface.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 8, 2002
Blckcivic01's Avatar
Blckcivic01 is an unknown quantity at this point
ya i get that same humming sound around 40 also.... its very annoying i duno what to do.... i raplaced my tires... and it still makes that sound how do i check the wheel bearing and try and fix it cuz its driving me crazy![IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Mar 8, 2002
also if its bad allignment how muchdoes that usually cost to get done? and where from?
Old Mar 8, 2002
kristy's Avatar
kristy is an unknown quantity at this point
Ever since my Konig's and new wheels have gotten put on, they hum really bad. I mean, they hum just goin like 25mph. not to mention when ya hit like 60 and higher it gets loud as ****...its weird too cause they were all balanced...but my steering wheel shakes at high speeds too so obviously they werent balanced right, or even balanced at all. Oh well I plan on taking it back to where I got them put on anyway. Hopefully tomorrow.
Old Mar 8, 2002
AJ's Avatar
AJ
AJ is an unknown quantity at this point
Hey Pounds I my tires are loud on the street I mean there LOUD but I have had a hummming niose for a long time in my driverside wheel well but It has been past 60mph. It sounds like a rubbing but nothing does. When I crack my window it goes away makes me think it is a pressure thing I don't know.
Old Mar 8, 2002
zappa's Avatar
Thats messed up... definitly not balanced at all , at high speeds mine are smooth as glass[IMG]i/expressions/beer_yum.gif[/IMG]
doncarbone
Jun 8, 2015 03:37 PM
cmart1209
May 29, 2015 04:52 AM
Optimus34
May 25, 2015 11:52 PM
bsmiley
Apr 27, 2015 01:27 PM
CapYoda
Nov 29, 2001 07:37 PM
