Which Redline MTF to order and how many?
Old Aug 1, 2006
silverem2's Avatar
Hey, long time since Ive been on here. Been out of the Civic scene for a while and got a few questions. Im ready to order the Redline MTF, but there are about 3 different weights/kinds. Which ones. Also, how many bottles will I need, if I need more than one.
Thanks In Advance. I did search, but nothing regarding the different kinds.
Old Aug 1, 2006
drunkenmagnum's Avatar
dumb question but what is MTF?
tranny fluid? i changed mine when i put the clutch in. it took less than two if i remeber right.
Last edited by drunkenmagnum; Aug 1, 2006 at 09:51 PM. Reason: Automerged Doublepost
Old Aug 1, 2006
v8eaterokv6's Avatar
i have a new home do u
its less than 2 quarts but i couldnt tell you the right weight as i would like to know to cause i need to change mine also
Old Aug 2, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
MTL, 2 quarts. tranny takes between 1.5qt-1.7qt's, i forget exactly.
Old Aug 2, 2006
silverem2's Avatar
Ok, Now I know how much to put in, which kind of the Redline fluid do I get.
Old Aug 2, 2006
ctx66's Avatar
Red Line MTL
Old Aug 2, 2006
silverem2's Avatar
Yes, but there is two different weights of them.
Old Aug 2, 2006
ctx66's Avatar
Nope, there is only one MTL. I used it for 90k, trust me.
http://www.gofastlab.com/marketplace...?productid=337
Old Aug 2, 2006
silverem2's Avatar
Ok, Thanks alot. Did you notice a big difference when changing? I havent changed mine yet, for over 100,000kms (yea, I know that's bad)
Old Aug 2, 2006
tranny fluid last a looong time, your fine
Old Aug 2, 2006
ctx66's Avatar
100,000kms on honda fluid is a very long time. Honda fluid is not very shear stable, it thins out pretty quickly. As a result, you should notice much smoother shifting, and come winter time, the car will probably be much easier to shift as well. Thats one of the main advantages of MTL over Honda fluid, is the cold weather performance. Those are the two main differences i experience, smoother shifting and cold weather shifting improved.
Old Aug 24, 2006
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
redline is good but i hear alot of guys on the S2K forum are using GM Synchro Mesh.. so i decided to use it.. WOW what a difference
BootyDo
Jun 21, 2016 03:45 PM
h4ldol
19
Jul 28, 2015 01:01 AM
EM_WON
Jul 22, 2015 06:49 PM
califcamper
Jul 21, 2015 10:34 PM
