Power steering cuts out...
My power steering cuts out on my k20a3 swap and the fluid foams up. I have no clue why it's doing this. It only happens when making slower turns other then that it'll work.
^^ not sure why it does that, but it happend to my old car where the power steering fluid would foam up and spill out every time i turn the wheel. Turns out the pump that circulates the power steering fluid was broken, so it just needed replacement. Not sure if thats what you need though. Sorry i tried to help
90% of the time is the pump 10% is the belt.
I foams up because at lower RPMs the fluid is not circulating properly, it could be an internal seal in the pump going bad.
It would work better at high RPM's till the seal completely goes.
Is the fluid container too full ?
it doesn't seem too full right now but it's hard to tell because it's so frothy and foamy. it does work better at higher rpms although i noticed it cut out. The seals being shot seams logical. The engine itself has been sitting around for at least a couple of years so the seals in the pump would have croded from not being used.
check all the clamps for the hose fittings cause a small leak on the lines could cause it to foam.. mine did... did a little tightening and it worked fine again.. and make sure the level is topped off
Originally Posted by Drivetofast
it will foam up becuase it is geting to hot and boiling, all you need to do is rap the high perssure line that gose over the header with some insulation
Originally Posted by supermex
If is leaking it would be easy to see, look for signs of it.
ok from looking at this pic and comparing to my car i found something. the metal portion of the hose on the end is threaded. well even though it's tight there seems to be some threads still showing. Is it a possibility that there is air coming through there?
RIPSAW
Nov 6, 2015 04:36 AM
moorebl
Aug 29, 2015 08:39 PM
hans.pcguy
Jul 12, 2015 12:19 PM
vvr210
May 31, 2015 08:02 PM
EdGasket
May 25, 2015 01:06 PM
