Power steering cuts out...
Old Jul 29, 2006
kornsined's Avatar
My power steering cuts out on my k20a3 swap and the fluid foams up. I have no clue why it's doing this. It only happens when making slower turns other then that it'll work.
Old Jul 30, 2006
D5cIvIc's Avatar
^^ not sure why it does that, but it happend to my old car where the power steering fluid would foam up and spill out every time i turn the wheel. Turns out the pump that circulates the power steering fluid was broken, so it just needed replacement. Not sure if thats what you need though. Sorry i tried to help
Old Jul 30, 2006
kornsined's Avatar
yeah it's odd. seems like there's air in the line still but the fluid was added properly. not unless there's a different way to add it in with honda/acura's.
Old Jul 30, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
How many miles are on the engine?
Did you buy the pump/assembly used?
Old Jul 30, 2006
kornsined's Avatar
25000kms, the pump assembly is the original that came with the engine.
Old Jul 30, 2006
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
90% of the time is the pump 10% is the belt.
I foams up because at lower RPMs the fluid is not circulating properly, it could be an internal seal in the pump going bad.
It would work better at high RPM's till the seal completely goes.
Is the fluid container too full ?
Old Jul 30, 2006
kornsined's Avatar
it doesn't seem too full right now but it's hard to tell because it's so frothy and foamy. it does work better at higher rpms although i noticed it cut out. The seals being shot seams logical. The engine itself has been sitting around for at least a couple of years so the seals in the pump would have croded from not being used.
Old Jul 30, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
check all the clamps for the hose fittings cause a small leak on the lines could cause it to foam.. mine did... did a little tightening and it worked fine again.. and make sure the level is topped off
Old Jul 30, 2006
supermex's Avatar
If is leaking it would be easy to see, look for signs of it.
Old Jul 30, 2006
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
it will foam up becuase it is geting to hot and boiling, all you need to do is rap the high perssure line that gose over the header with some insulation
Old Jul 31, 2006
kornsined's Avatar
thought about that but it does it right on start up. the turbo has also got some heat wrap, so there shouldn't be enough heat to boil the fluid. otherwise my cruise control box would be melted.
Old Jul 31, 2006
not necessarily so. if it has a tiny crack on the hose where it sucks the fluid it wont necessary leak out. the crack could be small enough to not let anything out but yet when the pump starts sucking it sucks air in through that tiny hole
Old Jul 31, 2006
supermex's Avatar
That seems like a possibility I'm pretty sure he already check into that.
I wonder if there is a pressure check that can be done, like pumping air or something.
Old Aug 2, 2006
kornsined's Avatar
ok from looking at this pic and comparing to my car i found something. the metal portion of the hose on the end is threaded. well even though it's tight there seems to be some threads still showing. Is it a possibility that there is air coming through there?
Old Aug 2, 2006
kasimmmmm's Avatar
same thing happened with my swap...
there's a leak in the hosing. tighten your clamps...
if that doesn't work, by new hosing, doesn't cost much.
Old Aug 3, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
haha dennis wanna give me your d?
Old Aug 4, 2006
kornsined's Avatar
i added more fluid and it helped but it still cuts out,just not as bad. I filled it past the high level line.
RIPSAW
Nov 6, 2015 04:36 AM
moorebl
Aug 29, 2015 08:39 PM
hans.pcguy
Jul 12, 2015 12:19 PM
vvr210
May 31, 2015 08:02 PM
EdGasket
May 25, 2015 01:06 PM
