WTT: Taylor Made R5 Dual Driver
Old Jul 10, 2006
PopcornPlaya's Avatar
Electric Boogaloo...
Looking to trade a pristine condition (I played 1 round and hit a bucket of range ***** with it) driver (Specs: 9.5 degree, Grafaloy Prolaunch Blue Shaft, Lamkin Tour Cord grip) for one of the following (in order of preference):
1. Nike Sasquatch 460 Tour 9.5 degree driver head (no shaft)
2. Cobra HS9 F series 9.5 Degree drive head
3. Ping G5 Non-offset 9.5 degree driver (with or without shaft)
4. Nike Sasquatch 460 9.5 degree driver (not the same as the tour, with ot without shaft)
5. Cobra F-Speed 9.5 degree driver with shaft
6. Titleist 905R 9.5 degree driver head
7. Cleveland HiBore 9.5 degree driver head
The ones that say head means I just want the driver head, no shaft, so if you or someone you know has one that's shaft is broke off, splintered, whatever, I don't care, just no shaft preferably. The only one I really would rather have with the shaft is the Cobra F-Speed. The rest I'd rather have shaft free because unless you have the shaft in it that I hit, it's going to be reshafted. No, I don't normally swing a Grafaloy prolaunch. I bought the driver and had that shaft put in it to try a driver with a slightly higher kickpoint and a tad lighter weight than I normally use (it's the same swing weight as my other 4 drivers, because of the head, but the actually weight is the same). If you do send one with the shaft in it, I can send you your shaft back as I won't use it unless it's the shaft I use.
Old Jul 10, 2006
djrabbi's Avatar
djrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to all
i have a 10.5 1 wood driver...... retail is $450
Old Jul 10, 2006
Brand, make and model? And 10.5 is going to put me too high above optimum launch I think, as a 9.5 should put me about 3 degrees above it. I've got a 7.5, 8, 8.5, and 9 already. I want a 9.5, even if it'll put my launch angle a tad above optimum, with one of the courses I play(conveniently the one I'm a member at), the added loft will allow me to cut the corner on two holes, as the tree on both doglegs is about a yard too tall to hit a driver on. I can fly it if I pure a 3 wood, but most of the time I hit a hybrid to the center stripe and play a long iron in. The 9.5 will allow me to cut those two corners, as the launch angle will clear the tree by about 7 yards. I could possibly cut two strokes off the score, maybe 3 or 4, depending on the second shot.
Old Jul 10, 2006
djrabbi's Avatar
taylor made...... which isee is the one ur sellin haah
Old Jul 11, 2006
The Quad TP driver? No thanks, the head is too heavy with all the screws in it. It's like swinging a weighted club.
Old Jul 11, 2006
djrabbi's Avatar
its actually reallllllllllllly light.... i can drive it 200+
Old Jul 11, 2006
I don't like a light driver. I like a light weight head and a lightweight (not ultralight) shaft. I hit it about between 275 and 295 depending on the driver I have in the bag.
Old Jul 12, 2006
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
if i still played golf i would have bought this from you.
Old Jul 12, 2006
bump
Old Jul 13, 2006
Bump I know someone wants this, I'll consider outright sales as well.
Old Jul 16, 2006
Been a few days... ttt
Old Jul 19, 2006
Will trade for above mentioned or sale outright for $165 shipped.
Old Jul 20, 2006
Bump some one please buy this...
Old Jul 21, 2006
bump $145 shipped
Old Jul 24, 2006
bump damned...
Old Jul 27, 2006
$130 shipped anywhere...
dlg1985
Jul 23, 2017 10:03 PM
17
Jul 23, 2015 11:48 PM
breanna_17
Jul 21, 2015 04:01 PM
CiViCPrAnInG2k1
Apr 2, 2002 06:34 AM
