Factory Radio Wiring Chart?
Old Jul 10, 2006
drixx12c's Avatar
drixx12c is an unknown quantity at this point
I've heard everyone talking about connecting power to the antenna booster in our car (yellow & green) wire in the factory harness. The Factory has 14 wires and my Head unit has 12. Could someone tell me what are the 2 extra wires for?? I know about the speaker wires(8wires) the power wire, ground wire, accessory wire, illumination wire, what about the other 2 wires??
Old Jul 10, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
your factory harness has 8 speaker wires, power, acc, ground, power antenna, illumination, dimmer.
headunits can have different # of wires, in your case, if you have 12, its 8 speaker wires, power, acc, ground, remote.
when connecting it to your headunit, dont connect the illumination and dimmer wires, and connect the power antenna wire from the factory harness to the remote wire on the headunit.
Old Jul 10, 2006
drixx12c's Avatar
Thanks for the reply, but what are the colors from the factory harness for the power, accessory, power antenna, illumination and dimmer?? I just want to be sure before i cross-wire anything.
Old Jul 10, 2006
05reverb's Avatar
i can get you the colours, but why don't you just get the 10$ harness that plugs in the factory harness and gives you all the right colour that matches the colours on your aftermarket Headunit. it's better to pay that 10$ than chopping your wires. its up to you, let me know if you still want the colours.
Old Jul 10, 2006
drixx12c's Avatar
i bought the adapter already, but there are 2 extra wires from the factory harness that aren't connected. I just need to know what they are? I just need the color codes for the 5 wires from the factory harness to be quite sure. Thanks
Never mind, i got your email with the pic. Wow. that helped a whole lot. I now know the wires. THANKS MAN
Old Jul 10, 2006
05reverb's Avatar
if you bought the adapter already, the 2 wires remaining on that adapter is orange and orange w/with stripe (illumination & dimmer), dont connect those. on the adapter, just match up the colours to your headunit and leave those 2 orange wires unconnected.
no problem anytime
no problem anytime
WaryDriver
23
Jul 22, 2015 07:18 PM
Youngciviboy
Jun 10, 2015 03:49 AM
tmort
May 11, 2015 07:13 PM
PK2K1
Jan 6, 2002 12:28 PM
AzNmiKex215
Nov 29, 2001 08:02 PM
