Injectors
Old Jul 9, 2006
BCCentaur3's Avatar
BCCentaur3 is an unknown quantity at this point
Injectors
I need help. I know RSX-S injectors work for our cars, but would i be able to make 450 DSM injectors work? If so what would i have to do to make it work. Any suggestions would work because I am going to turbo before I go back to school and need to know.
Old Jul 9, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
I'm thinking you'll need a resistor box.
Try SRT4 injectors, they're ~450 and I think they're more or less PNP.
Old Jul 9, 2006
BCCentaur3's Avatar
If SRT-4 injectors fit, how would i wire it up?
If i do use a resistor box with the dsm injectors, would i wire it up the same way i would with a 5th or 6th gen civic?
Old Jul 10, 2006
tfnaaf's Avatar
BLDNPSI Mod
my understanding is the srt-4 injectors will fit BARELY(just need injector clips), anything bigger requires custom work with TPS/throttle body/fuel rail clearance issue
Old Jul 10, 2006
BCCentaur3's Avatar
since SRT-4 injectors fit, which year will fit right? From my understanding the 05 srt-4 injectors would be an upgrade for the 03 srt-4. Since srt-4 injectors fit, how come there aren't anyone talking about using them for their turbo setup?
Because if you are positively right about the injectors fitting I will put the order in on them.
I just need to know how i can have a good fuel system for my turbo setup, but also save enough money for school.
Any help please.
Old Jul 10, 2006
tfnaaf's Avatar
BLDNPSI Mod
Any help please.
I dont know for sure that they will fit, but its been posted before that they fit with the addition of the clips. How much PSI/HP are you aiming for? you may not need anything bigger than RSX's injectors
Old Jul 10, 2006
BCCentaur3's Avatar
I am just going for 6 PSI at the most, I am on a budget and I basically have everything except for the injectors. Without them I can't finish my project this summer. And I am desperatly looking for answers. RSX injectors are too expensive. Theres a guy on ebay that will sell SRT-4 injectors for 70. I just need the clips.
Old Jul 10, 2006
dezod's Avatar
7thgen Power Maker
Probably just a standard RC clip will work.
Old Jul 10, 2006
BCCentaur3's Avatar
So I will go with the SRT-4 injectors. Wish me luck i hope it turns our fine.
Ok what do you mean by standard RC clips?
Nevermind that question it was stupid, hopefully this question isn't stupid. How will i wire the clips on to my car?
please excuse me I am new to this stuff.
Last edited by BCCentaur3; Jul 10, 2006 at 10:35 PM. Reason: Automerged Doublepost
Old Jul 10, 2006
tfnaaf's Avatar
BLDNPSI Mod
rsx injectors go for less than $80 usually
Old Jul 10, 2006
BCCentaur3's Avatar
your talking about 80 each, I went to the Acura dealership they told me 700 for a set, then i went to Checkers they said 310 without the core, which i don't have. I am saying 70 for a set of srt-4 injectors. I can't turn that down. Especially if they fit. Just gotta figure out how to wire them up.
I can't let the last and final obstacle mess me up from my 3 years of planning. All i need are injectors and I am done.
Last edited by BCCentaur3; Jul 10, 2006 at 11:03 PM. Reason: Automerged Doublepost
Old Jul 11, 2006
tfnaaf's Avatar
BLDNPSI Mod
Used ones is what im talking about and are always available searching
Old Jul 11, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I has dsm 450s with the resistor box. Cutting them back at idle they really work like crap even with the AEM. Ill be hopefully switching back to RCs sometime in the near future. The dsms probably would be a biatch to fit on a stock intake manifold config.
Old Jul 11, 2006
dezod's Avatar
7thgen Power Maker
So your idle is lumpy?
Are you sure it is not from the cam and compressor surge?
Old Jul 12, 2006
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
srt-4 injectors and v-afc2
for my fuel option i went with v-afc2 and rsx-s injectors.... i found out later it was a mistake.... the rsx-s injectors and emanage is the best combo....
but what about srt-4 injectors and v-afc2????
Old Jul 13, 2006
Michalo187's Avatar
Abortion Survivor
Don't run srt-4 injectors unless you get the ems. You will run extremely rich and you won't like the results. The srt4 injectors also take a lot of fuel pressure. I even had a little trouble with them on the ems but we figured it all out. The fit is extremely tight. I had to take off my tb to install them and then the tps is hitting the fuel rail thats how tight they fit.
Old Jul 14, 2006
BoostedVik's Avatar
yeah, if they are that big of a bitch then **** them.... emanage then ha?
i just need the support tool? i mean the usb cable that connect to emanage, i got the software on my laptop already!!
runawaykinms
15
Mar 22, 2019 10:32 AM
Dave Brabant
Sep 27, 2015 09:43 PM
Luluharp
Sep 27, 2015 11:56 AM
Bruce2
Sep 21, 2015 08:01 PM
Donahue
Sep 9, 2015 05:55 PM
